Elite Catch Can for 5.3
I'm running the Elite E2 single inlet/outlet with check valve and CSS.
Nice set up. I mounted mine on the windshield wiper bracket.
  • Replies 51
I've had mine there and on the brake booster. Current location is the easiest access for me to dump the can.
Interesting.. Did you use the supplied hose or did you buy your own? And if you did use the supplied hose, any hissing noises?
I went ahead and bought 250 psi locally and installed it. The stock hose is definitely softer than the hose I used. This is my third different catch can on 3 different trucks. I've replaced the hose on all 3 installs.
Ive got the ex2 w/ css single port. Bought it after doing a lot of research. I didnt want to cheap out and figured its a one time investment, might as well spend the money for peace of mind. Installed it on the brake booster and after the first drain there was already oil/gas/condensation build up. I installed mine at 4k km I wish I did it sooner! I would highly reccomend the e2x, i would buy another in a heartbeat. Also it was easy to install, 30 mins tops after fightong the hose and fittings to seat properly.
Was the CSS decided upon based on your research? I'm sold on the e2x but not yet convinced on the additional apparatus. It seems to be more for forced induction and/or "sporty" type vehicles that are driven harder than a truck typically is. I have no problem paying for it if it is useful or a good idea. What I detect here, however, is folks getting the CSS just because it came with the kit. Maybe they didn't know the e2x can be had without?
good info to know
These are vacuum hoses they won't blow off so no need for all of the fittings and bullshit. I have an Original RX can on my boosted 5.3 w/clean side seperator. I empty once a year during the oil change and I might get 5-6 oz's and my intake valves are as clean as new.
RT
I'm kinda pissed off elite read my message and did not respond. I thought they had great customer service... wtf
I,emailed elite. They messaged be back in less than an hour
Elite does have good customer service. Whats your gripe with them.
They sent me the wrong hose for the catch can install. After speaking with another member, they told me they received hose that was rated for at least 150PSI and i only received 35 PSI hose...
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 485 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
