Morning delayed and harsh engagement?
What would cause a delayed and somewhat harsh engagement in a 6 spd in a 2012? Got about 100k, fluid and filter changed regularly, no CEL or codes I can scan.
Sent from my SM-T350 using Tapatalk
Weak pump.... Bad valve body or solenoids. Aftermarket makes nice stuff.
Sent from my SM-G930P using Tapatalk
Ok, so off to the dealer then...
Dealer isnt going to Upgrade the Pump with a Sonnax boost valve, or put in a updated valvebody .
You need a shop near you that can and will do it right, then test it on a dyno.
I would do a new , or reman pump with this>> http://www.sonnax.com/parts/3069-boost-valve-kit
And a reman Valve body. Some aftermarket rebuild kits are excellent for durability and longevity.
good luck!
PS... cl2Sparky has a valid point.. make sure its up to temp and isnt above 200
sent from my 4GHZ Dual Quad core desktop !
Is the warrantee on the truck up? If not, I would definitely get the dealer to fix it...
Good point... Even if you're over 100k there's a good possibility of dealer getting Goodwill money
Let me describe it better, it does it once, after sitting overnight, when cold.
Doesn't do it after the initial engagement..doesn't do it after sitting eight hours at work. Does it frequently, but not every morning.
Once that initial drop into drive is done in the morning, truck drives and shifts fine the rest of the day...
Fluid level too low?
so long
j-ten-ner
Nah, fluid level is good...
Doesn't sound like it's worn out if it only does it once. Maybe trans. fluid temp. sensor out of range. I would let the dealer have at it.
If I had to guess what if feels like is that things aren't primed. Like the system isn't pumped full...and these pump fluid in Park correct?
    250.3k
    Disabled Mike
    Disabled Mike
  • Who's Online   2 Members, 0 Anonymous, 739 Guests (See full list)
