Robbins14 Posted April 3, 2017 Posted April 3, 2017 2007 silverado 1500 nbs. My truck seems as it over steers badly at highway speeds. I jacked it up and ball joints and tie rods are tight. Not sure where to look. Thanks
jrow8162 Posted April 5, 2017 Posted April 5, 2017 Did you check the Idler and Pitman arms? Any play in the front steering when you jack the truck up? You should see them moving up and down when you move the wheel back and forth.
ernbrdn Posted April 14, 2017 Posted April 14, 2017 If this is a 4wd with a center link the center link can actually be installed backwards/upside down and cause this. It will look correct but in fact be wrong. Pro tip it actually looks like it's installed the correct way when it's upside down, installed correctly it actually looks wrong. Sent from my iPhone using Tapatalk
