Door adjustment
My 14 sierra driver door doesn't seem to seal. No water intrusion but I can hear/feel a bit of wind. Is there an adjustment/fix to get the door tighter? All rubber seals are in good shape..
Sent from my SAMSUNG-SM-N920A using Tapatalk
I had a rear door window seal leaking and thought at first it was the door seal. I put black tape on the window against the window seal to find where the leak was. I would check that before adjusting the door. The dealer tried adjusting the door several times and that was not the problem.
