I have a 1999 GMC Sierra 1500 extended cab. NBS Also have a build thread!
I have been chasing a problem with my interior dome lights not wanting to shut off for a couple years now!
Its not the dimmer switch turned to full on! I use the dome override and have just lived with no dome lights for the time being!
I really doubt it's my body control module going bad as everything else functions properly, I.e. key in ignition chime when door is open.
I am hoping someone​ can point me in the right direction with my multimeter to hunt down the cause!
I'm not 100% familiar with what all this truck uses to trigger the dome lights I.E. if it has door ajar modules and there location. The lights also do not shut off after 20 mins, I think I read somewhere they are supposed to do that.
This is the model that the dome override switch does not shut off the automatic headlights if that makes a difference in wiring schematics if someone can find some for me![emoji2] I found a schematic on AutoZone of all places but am not sure it is correct for my model year since I have a half breed year truck!
Sent from my XT1254 using Tapatalk
I'm new and still figuring out this forum, but I'm guessing I should have posted this in the ask a GM tech or the electrical sections
  • 3 weeks later...
I own a 1999 Silverado 1500 and have had a similar issue. I'll say this, my security light would continue to blink even when the doors were shut. I replace the door actuator. After disconnecting plugs and looking at schematics I used a jumper to test my theory if it was the problem. Went and got a used one and presto, security light stays off, courtesy lights go off and on like they should. It's worth a shot to try. Mine ended up being the driver side.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Security light goes off when doors are shut. I actually made a build thread for my truck! After I get done doing some cosmetic repairs I'm going to get into fixing this, only time I miss my courtesy lights is when its dark and I'm grabbing something from the passenger side and I have to walk around to shutoff the override. Then walk back to passenger side, grab item, and walk back again to driver side to turn on override.
Kind of a PITA but manageable. I also just discovered my third brake light is not working, but the cargo light operates fine, but that is a separate issue. Also keyless entry door locks do not lock anymore, but they will unlock, I think they are just tired from old age and I found that I have to buy the whole latch assembly to fix them, maybe​ this will also fix my courtesy light issue as well, but it's probably not that easy. Never is!
In case that gets confusing, I meant that the security light only blinks when doors are open, and it does not blink when doors are closed, also alarm operates perfectly, so I think it is a separate issue in the form of an exposed wire that is grounding the circuit to keep lights on constantly, so I need a circuit diagram to find all the wires and trace them for bad spots
Hmm, that tells me the door actuators and the components do work then. Since the security light stops blinking when doors are shut. It could be a wire issue. Another 1999 Chevrolet I use to own I had an issue where a power wire for the window controls broke somewhere in the harness. I'll try to look at my schematics and pin outs to see if I can help you out!
  • 4 years later...
Please please please tell me you figured out how to fix this? I am having the same issue but whenever I press dome over ride they won't even turn off.
I have some thoughts on what my issue is but I want to see if you figured it out first.
  • 2 months later...
I figured this out later on. Turns out I had grounded/powered my puddle lamps to the wrong spot on accident.
    JimmyB4
    JimmyB4
  • Who's Online   4 Members, 0 Anonymous, 847 Guests (See full list)
    • I’ve own several successful businesses. I’ve bought homes and lived in different states. I’d witness several generations buy homes and survive in different economic circumstances. You get awful sippy when people have different experiences than you do. You live a life. I’ve lived a life. It seems our experience has been different. You can point out generalized statistics. Some people learn how to thrive when the odds are against them. Living in different states does make a difference in a persons quality of life and economic outcomes and opportunities. That’s a fact Jack. It’s my truth, my life. Hard work and long hours the right environment made my families life easier. And yes moving to a different state increased the odds of that happening. Stats are generalized. People who thrive don’t make excuses. They beat the odds. Others get mad and point to those statistics. I guess that’s you. My post pointed out how you helped people beat the odds. Somehow your panties got in a wad. Go figure.
    • Good question, I don't remember for sure but I believe it was the HD. I will check and get back to you.
    • Point of the post sir was that while both wages and cost are rising EVERYWHERE; the cost is rising faster EVERYWHERE than the ability to buy EVERYWHERE. We're not going down the location rabbit hole. I'm aware of what economic migration is. I've lived in four states including Texas.   It's what "Purchasing Power" means.   I'm not telling you what I think. I'm telling what the government, your government, data shows.   It wasn't an argument. It wasn't a suggestion. It was a statement of FACT. You are absolutely entitled to your own opinion. Your not entitled to your own facts. If you and I were, they wouldn't be facts.    fact /făkt/   noun Knowledge or information based on real occurrences. "an account based on fact; a blur of fact and fancy." Something demonstrated to exist or known to have existed. "Genetic engineering is now a fact. That Chaucer was a real person is an undisputed fact." A real occurrence; an event. "had to prove the facts of the case." The American Heritage® Dictionary of the English Language, 5th Edition • More at Wordnik   If you'd like to disagree call your Senator or Representative and let him know his departments are in error. But you and I? We are not doing this.
    • Probably a one and done post, but do you have a CEL on the dash? Was having issues with my transmission, fortunately only a week, and it turned out to be the transmission harness. Valve body was in good shape, so new harness with all the sensors attached, new fluid, and filter. Seems to have worked so far?
    • Two interesting tidbits of information which are NOT related were just released.   One, regarding the possible thrust bearing issues / engine failures with the 3.0. Demonworks just did a segment in which they believe they may have found "a" or "the" cause of thrust bearing failures: A missing thrust bearing. If the engine doesn't have all its thrust bearings from the factory, the missing bearing can cause extra play which ends up destroying a nearby thrust bearing which then sends metal through the engine.       Of other importance, Lake Speed Jr released some interest information regarding oil weight selection for the 3.0. Comparisons of:   AcDelco 0w20 Dexos D Mobil 1 ESP x2 0w20 Dexos D Mobil 1 ESP x2 0w30 Mobil 1 ESP x4 0w40. Mobil Delvac 5w40   Spoiler alert: The Mobils are PAO Ester -base and the ACDelco is a Group III base. Mobil shows lower wear in their tests for similar weights. Additive packages between 20-30-40 weight ESP's appear to be the same, but only 0w20 is Dexos D licensed. Wear is even more reduced with 30 and 40 weight ESP although all perform very well and resist shear and provide very similar viscosities within temperature operating ranges in the 3.0.   There are even more surprises, so just go watch it.
