WAY off-topic question
MountaineerTom
If you've ever noticed, regular sized office staplers have a plate on the base part that has the little indentions in it that cause the tips of the staples to bend.  On most of them, that plate rotates so you have a choice of the tips bending inwards or outward.
Why is there an option to have the tips to bend outwards?  Why is there a need for two different directions for the tips of the staple to go?  ???
:D
You know Tom, I have always wondered that same question myself forever.  I don't get it either?  Maybe someone will be able to tell us why?
It's only found on military staplers.  Stapler manufacturers came up with it as a "national defense option" costing an additional $400.00 per $12.00 stapler.  The military, of course, went for it. :D
From the Swingline.com web site
What is a flat clinch stapler?
A flat clinch is when the staple legs are formed flat on the bottom of your paper. A standard clinch is when the staple legs on the bottom of the paper are curled.
What is the advantage of a flat clinch?
Papers stapled in this fashion stack better and the paper capacity of the stapler is increased.
What is the largest staple made for the heavy duty manual staplers?
We produce a 15/16" heavy-duty staple, item number 35320. This staple only fits the 90002 heavy-duty manual stapler.
Maybe it is one of those Euro things, like the wrong [other] side of the road :baa:
:baa:  That's exactly what I said.  The metric version of stapleing paper.  :D
I don't really understand how the paper capacity is increased, since the staple is the same size, just the ends pointed in different directions.  ???   Thanks though.
The only thing I can think of is the thickness of the staple after it has been stapled. When it is done outwards, it doesn't fold over itself and therefore isn't as thick.  ???
