How does this come off? (pic)
How do I get that black trim off on the doors? I was in a small fender bender and I need to replace this piece on my pass front door.
Any idea where I can get it cheep?
Are there holes in the door once removed (thinking...take it all off)
MIke
There shouel be no holes or anything behind it. Just held on with double sided tape. Here's how to remove it: http://www.gm-trucks.com/IAR_decalremove.shtml
As far as were to find it, you may be able to find someone selling the trim they removed on EBay, but I doubt you'll be able to find just that specific piece. You could get brand new from the dealer, you MAY be able to get just that piece from them, not sure.
It would look good removed, but I like the little bit of protection that it does provide. :cheers:
THanks!
I read that article before but never realized it was for that trim too, thought just for emblems!
I was thinking getting one at a junk yard, but that would be a mess to re-attach im sure!
I can't believe that whole thing is held on with adhesive.
Humm, now what to do, I kinda like the look of it,,,,like the protection, but wonder what it would look like without it!
Anyone have any pics?
Mike
It is not to bad to reaply the molding. Get some doublesided tape from an auto paint supplier. The tough part is to get the old tape off the old molding. Then hold the new redone molding in place and mark where you you want to put it with masking tape. Then pull the tape cover off the new molding and put it on. Just be careful as when it sticks it is stuck.
Chevy4X4
THanks for the photoshop job, looks pretty good! Actually like it! I was htinking of getting color keyed stuff, but I kind alike this idea better...Im sure it will be FUN getting all that adhesive off now...Man thats probally a nightmere!
Thanks fot the tips guys! THink if I can;t find a replacement cheep....off it all comes! :cheers:
Mike
I used mineral spirits to get the adhesive off. I first wiped some mineral spirits on the adhesive, and then dipped a cloth in mineral spirits and used the cloth to nudge the adhesive. Mineral spirits makes it come off with just some nudging. It was time consuming though.
If you use a good hot hairdryer, it will heat up and come off. Or set it out in the sun or a heat gun. Once heated, it comes pretty well.
Just be sure that if you use mineral spirits or rubbing alcohol or such to remove the adhesive, and are going to take the moldings off, that you apply a good coat of wax to the area as you will have stripped whatever was on before.
Just get ready for more than your fair share of door dings.
I pulled all the trim off of my 92 right after I bought it, and have spent quite a bit of cabbage having the dings removed from time to time.
Note that it's still off, as I do think it looks a LOT better without.
Just thought I would warn you. :cheers:
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 484 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
