Chevy Shake and Tire Wear?
Was thinking about this the other day while I was putting loads of miles on during our road trip.
Do any of you worry about or think that our shaking issue could cause any premature wear on our tires? Might be a hard question to answer as we arent all 100% sure how to fix the issue, and without knowing how to fix it means we are a bit unsure whats actually happening, besides the shaking.
But if the car is shaking and might be a suspension thing, or drive shaft??, makes me wonder if its causing other things, such as our tires to wear uneven, or prematurely?
FWIW, I rotate the K02's every 3,000 miles to hope for longevity.
I wouldn't worry too much about the tire wear. Especially if it's a driveshaft vibration. The frequency at which it vibrates isn't enough to register on an oscilloscope as a Tire1 or Tire2 vibration, so it wouldn't be rotating at tire speed. This is just going to be something that transmits to the cabin from the frame to cabin body mounts, which is why it's so noticeable.
I don't think vibrations felt in the cab will necessarily equate to excessively worn tires. That is unless the vibration is coming from misaligned tires.
I'd be more worried about the driveshaft. Didn't somebody claim to have fixed the vibration by replacing the driveshaft?
I'm just going by posts I have read, as I have no vibration issues myself.
Makes sense. Yeah there is a guy on the Troubleshoot side that said he replaced his driveshaft and solved his issues. Said that when it turned, it looked like a jump rope if i remember correctly, it was balanced but not straight.
get anxious thinking about going through all 700 pages of the shake thread.
These driveshafts are paper thin. Seems like a steel one would be better. I may try it.
Sent from my E6810 using Tapatalk
Yes, member 07softtail I think.
My drive shaft was both out of balance, and not straight. Both were addressed by a drive line company, which vastly improved my vibration problem. But, it didn't entirely eliminate it. It still has a very high-frequency vibration. The dealer told me it wasn't the drive shaft to begin with...but it actually was a part of the problem.
The dealer (for about the third time) has blamed the tires. I've had four sets of tires (two different brands) installed in the last few months (Firestone paid for all thinking the tires were the problem). On the last maintenance cycle, the dealer told me I had three bad tires (again). I went back to Firestone, and they printed their results (after a rotation, balance and index) and disagreed with the dealer that the tires are bad. At this point, I believe Firestone.
I think there are a couple of possibilities:
  • A harmonic reaction caused by inadequate damping between the body and frame (or suspension components)
  • A hub or axle assembly that is not true (similar to the driveshaft issue).
Either way...right now I'm just living with it. I'm buying a new tires in August (and will go with a third different brand). If that doesn't work, I'm through with GM products.
    appletrav
    appletrav
  • Who's Online   3 Members, 0 Anonymous, 224 Guests (See full list)
