2015 front suspension / steering click pop creak knock rub squeak tap
My truck makes 2 noises every time I back out of the garage and into the street. My driveway slopes down away from the garage and a little to the left, and there is an asphalt curb at the end that I have to roll down into the street. The street slopes up to the right. So basically I am backing down into a valley and turning 90 degrees to back up the hill so that I can drive forward down the hill.
When I'm about halfway out of the garage, I turn the steering wheel a little to the right to start the bed moving to the right. At that time I hear a single tap from the front of the truck, it sounds like a hammer lightly tapping the frame of the truck.
Then at the bottom of the driveway the rear wheels roll down the curb and up to the right as I'm turning the wheel to back up into the street. When the bed rolls down the curb as I'm turning, it picks the left front end up away from the tires and there is a single creak, or rub, or knock, again from the front of the truck. It sounds like a shaft turning in a tight rubber collar, or a snug bolt that is sliding in a slot.
I have 29,000 miles and it has been happening for a long time. The dealer said they tightened the front crossmember bolts but that didn't fix it. I've tightened the front sway bar bolts, the upper ball joint nut, the three nuts on top of the strut, the rear U-bolts that hold the leaf springs in place, and the center crossmember bolts.
I believe the noise started while the suspension was stock. I added a 2" front leveling spacer under the strut, then took it out and put in a 1" spacer on top of the strut. None of that seemed to make any difference. The 1" top spacer is in there now.
The noises also happen in parking lots. Only at low speeds and I think only when turning.
OK I welcome any suggestions, thank you everybody.
Sounds like a worn upper balljoint. Mine started right after I leveled it 2". I had 12k miles on the truck
  • 1 month later...
Turns out it was the REAR springs! I soaked them with WD-40 and the rub/creak went away. It lasted a few weeks and now I'm in a normal maintenance mode of spraying the leaf springs every so often, I see a lot of other posts with people complaining about the same issue.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
