18" tire size
2016 2500 raised two inches in front could go more with new control arms. finally settled on stock 18" wheels.
had some 20s just can not get myself to like them.
deciding now between 295 70 18(more than likely) and 275 70 18. anyone have a picture of the 275 70 18
to look at ?
275/70/18 will look a bit small with 2" of lift. I'd definitely recommend the 295/70/18 or 285/75/18. Those are probably the two most common sizes for a level and stock 18" rims.
Agreed, go with the 295/75/18, the 275 will look small on a 2500
​Here is my truck with fuel wheels and tires. Tires are 275/70/18 Nitto Terra Grappler G2 with no lift or level kit.
I think there's a typo. Do you mean 295/70 or 285/75?
275/70 is a good setup for stock height :thumbs:
  • 9 months later...
I have duratrac 275/70R18's on 18 x 9 fuel rims with around 20mm offset. I have zero rubbing at any time. Any bigger and there would be some rubbing. I think they look great with my truck being leveled. I would post pictures but haven't been able to on this page for a long time.
4 hours ago, Dtz7116 said:
Any pictures of the 295/70/18?? If so was there any rubbing? Thanks!
I put a set of Michelin LTX MS 295/70r18 on my truck. At first I had front mud flaps but tires found them once I removed the mud flaps, no rubbing.
