Old school led strips
I need some help I'm trying to track down some old school led light strips. They use to make that you install in a aluminum track with the arrow ends. They were thin came in all diff colors and sizes. I wanna install them on my running boards. Does anyone remember the name of them. I tried googling but no luck. Thanks
I thought I'd give it a quick search and found this. http://www.ledlightsworld.com/flexible-led-strips-c-1_49.html It may not be exactly what you are referring to but they seem to have a lot of alternatives!
Yeah. Good luck finding those. Tech has moved on to using rolls of adhesive LEDs . You can get them waterproofed. I'd mount some on a strip of aluminum cut to fit and slip it in the track. Make sure you use some adhesion promoter on the surface so the LEDs stick and don't come off.
Sent from my SM-G955U using Tapatalk
There's a place called Radioactive in locust grove GA that used to have a bunch of them left over from years ago. You may try calling them
