Wow that looks like the same spot I have oil coming from but mine isn't all messed up.
Think the engine was swapped at some point?
I'm guessing it was previous owner didn't give much info on it even thou I asked. But mainly my fault for not going under to check everything.
Sent from my SM-G935T using Tapatalk
Fix it. Move on and chalk it up to lesson learned. :happysad:
Haha that's the plan just short on funds at the moment but will get all this fixed
As long as it's running fine till I save up for an another engine ill be good
