Battery Replacement-Ugh
I would not let anyone else change out my battery, after doing it myself, i found it would be extremely easy to accidentally touch the wires together. Too many connections and too tight of space to work in.
DIY job for the sake of your truck
also wasn’t happy when I lost my “best” mpg stats lol
  • Replies 36
When I bought my truck used it still had the OEM battery, about 4 years old.
First thing I did was put in a new one.
The old front mount battery was easier for sure but servicing the trans really sucked.
There was a new Walmart battery in my low mile 09 Buick when I bought it and from day one I would get random alarms on the display, like low oil pressure, parking brake on and so on. We don't drive it much and it sits on a Battery Tender most of the time. Of course one day it croaks. I replace it with an Interstate Battery then have the Walmart battery tested. Dead Cell. Evidently dead from birth. So it sat just above the 9.5 volt threshold and would trip alarms. Hasn't had an alarm since. Jason, my head wrench tells me that he has replaced dozens of Walmart Batteries  with dead cells under a year old. The Interstate was $20 cheaper. I've been using Interstate since Sears Diehard became Sears DOA.
Checking battery voltage is a good way to evaluate battery condition IMO.
If the vehicle sits for a while, say a week the voltage will tell how the battery is doing.
I used to use a Fluke DVM to check battery voltage until I found this:
https://www.amazon.com/gp/product/B000EVWDU0/ref=oh_aui_detailpage_o03_s01?ie=UTF8&psc=1
Works good, easier and faster.
Had a 99 GMC.  Battery lasted 13 years in Manitoba Canada.  Does get to +90F here in the summer but not a lot.  Gets to -30 or 35F in the winter.  Had 160,000 miles on it.  Used a battery blanket in the winter and a small piece of plywood under the battery.
Jim
CYWG
The battery in my '14 just died this week.  I've owned the truck for 3 years, 2 months but the truck hit the lot a full 4 years ago so I'm surprised to see an OEM battery dead during winter.  Will be replacing with an Interstate MegaTron Plus. I've put one of those in every vehicle I've owned and never had one fail before 6 years. Some were actually transferred to the next vehicle and just kept kicking.
I’m at 109,000 on my 14 and I’ve left light bars on enough where I drained the batter roughly 10-15 times over they life time and still haven’t killed my battery.
I’m in Alberta, Canada. This truck spent a lot of time in Fort McMurray in extreme cold(even killed the battery there a lot).
In my opinion, fantastic battery.
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
