I remember when my truck was untouched and new my steering wheel controls would light up but then I put an aftermarket stereo now my controls don’t light up anymore is there a fuse that I could replace for the back light to work ? 2014 Silverado crewcab
My 14 did the same thing. I don’t think it’s as easy as a fuse. I remember that the instructions that came with both of the SWC adaptors it tried specifically mentioning that the back lighting would not longer work.
Until I got my 17, I honestly forgot that they used to light up and I had no issues just doing it by feel.
Yea that’s probably what mine said as well thanks for the reply
That's interesting to note.  The only time I have seen mine not "light up," was about a year into ownership, and then I cleaned my steering wheel, removing dead skin cells and wife's makeup residue.
Recently, I was looking at replacing my stereo with one that has NAV and a 6-disc (MP3 compatible) changer in it, like my '10 Ridgeline did.  But now, maybe, I'll put that one on the back burner, until I find one that I know for sure will work with everything else in my truck.
  • 5 years later...
I changed the stereo and the steering wheel control switches about the same time, so I wasn't sure why the new ones didn't illuminate. Now I know!
  • 5 months later...
i swapped harnesses and I am not using the Maistro and the controls are illuminated.
  • 6 months later...
how did you get them to illuminate?
  • 7 months later...
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
