On ‎2‎/‎13‎/‎2019 at 2:00 PM, Big Whiskey said:
Same for me. I think the "rattle" I was hearing was the shocks bottoming out.
Where does one find these shock spacers? Sorry I am new to the 3/4 ton world and also new to GMC.  Converted over from Ford F150's but mine does the same thing it rattles a lot, still under warranty but I am curious about these shock spacers.
They are pieces of pipe that slide over the top studs of the shock between the shock and the bottom of the frame and space in downward.  Some outfits make a pretty little block but it does the same thing.  You will need new shock nuts as the OEM nuts are like an inch long and only threaded at the top so they don't engage.  When we did new shocks on my buddies 2011 they came with new normal lock nuts so we cut the thread off the factory shock nuts and slid them over the studs creating our own spacers for free lol.  Pull your shocks out, slide the spacer on the studs and reinstall.  Voila.
Well I found the reason my truck was rattling so bad.  I have to broken welds on my running board support arms.  I know this will more than likely not be anyone else's issue, but it was my issue.
I bought mine from www.sinisterdiesel.com, but they were Zone Offroad brand. A simple Google search for 2500HD shock extensions will yield all kinds of results.
  • 9 months later...
  • 4 months later...
I have a 2010 Silverado Ext. Cab 4x4. Mine does the exact same thing going over bumps and/or rough terrain. It really does feel like the entire suspension, wheels and all, is just going to fall out. 3 months ago I replaced the upper and lower arms, new ball joints, struts, 3" leveling block, inner and outer tie rods, all brand new U.S.A. Moog parts(the good moog parts) and everything set to factory torque specs. Didn't fix the problem. Seriously need ideas/help!
  • 1 year later...
On 1/21/2019 at 10:35 AM, bullitt_bee said:
I know this is an old post but i'm having what I think is the same issue. The dealership replaced the front shocks and rear leaf springs but the problem is still there. Video tries to capture the sound of rattle but is more more defined and "loud" in person. Thoughts?
 I have a 2019 that was doing the exact same thing took it to the dealer they replaced the pitman arm and it fixed 85% of the issue but it’s still there I’m thinking of trying the cogito pisk to see if that would maybe eliminate the “play” noise I’m hearing. Did you ever get urs figured out?
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
