You won't lose anything with duals.  Honestly run what you want and ignore 90% of the rubbish on the internet.  I have 3" duals on mine and gained everywhere including right off the bottom... kind of goes against most internet wizards that not surprisingly can't change their own oil in real life but know every old myth online lol.
There was/is a video out there where they dyno'd open headers, dual 2-1/4", and dual 3". There was very little difference between open headers and 3", but a pretty good loss with 2-1/4".
There was not magical loss or gain in bottom end like is always stated...
Steve
2012 2500hd 6.0l
Steve
2012 2500hd 6.0l
So what does that prove, he said he has 3" so if anything he is kinda right...no?  Me, I would always go with someones personal opinion with their own truck on weather or not they "feel" the difference.
I have had true dual exhaust on every truck i have owned and i too felt the difference.  It IS IMO worth it for the looks, sound, and ive never had a reverse effect on power/torque personally with experience.   If at the least (depending on the truck) it was never worse, a little better if anythng.
Can you post picks or the setup if possible? Is it dual mufflers or single?  3-1/5" in > 3" out?
Lol, that is exactly what I thought about it
You missed the point completely...it makes no difference. So much Internet lore about losing bottom end with big exhaust...I was actually supporting his point.
Have a nice day...
Steve
2012 2500hd 6.0l
Have a nice day...
Steve
2012 2500hd 6.0l
Just ignore like I said originally.  It works better.
Have a nice day...
Steve
2012 2500hd 6.0l
yeah, thats what i thought...thanks
  • 4 months later...
HOw did the Headers work out for you?
What Part # and make did you end up going with?
  • 3 years later...
Just signed up for the forum. I can't see where you purchased your headers. I've got a 2017 GMC SIERRA 2500 HD SLE 6.0 2wd.
Looking to improve my fuel mileage. Wondering do I just do CATBACK or should I go full bore and do headers.
I tow a 12,000 pound 5th wheel.
I don't see headers or a cat-back exhaust improving your fueling at all when towing 12,000lbs.
Headers move the powerband up some, so you'd lose a little bottom end torque which I wouldn't really want.
If you want more sound just chop the muffler out and straight pipe it or put a different muffler on it. The pipe size is already big enough so doing a catback isn't required.
Different rear end gearing would be what I'd look at for better fuel mileage. If it struggles to keep speed because it has something like 3.73's then going to 4.10's or 4.56's would help with that.
Can someone please post which headers they got. Will be going on a 2016 chevy 2500 6.0.
I have Gibson cat back, s&b intake, and cats will be deleted with tune.
any information is appreciated
  • 3 months later...
Same here, I've yet to find a long tube header that fits a 2014-2019 2500. The 2500 trucks have a factory body lift and that I believe is what is causing the fitment issues with the long tubes , and y pipes for 1500 trucks that are already available.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
