JUST AN OBSERVATION.............
SO, I have found that, occasionally, my driver side mirror will not unfold, when I unlock my truck, but the passenger side will.  Not sure why this happens at least once a week.  After several attempts to "unlock/unfold," I have discovered that after the first attempt to unfold, it is better fold the mirrors back in, and unfold them again.  I'm not sure if some lug-nut, out there, keeps coming by my truck, once a week, and tries to manually unfold my mirror.
Edited by Ravenkeeper
Font size
My passenger side tow mirror occasionally flakes out and either doesn't fold when commanded to, or only folds partially. I've never had an issue with it unfolding though. Mine seems to do it only when it's cold outside from my observations. Thought about bringing it to the attention of my dealer next time through and hope it's covered under the extended warranty.
My passenger side does the same...Sometimes it doesn't fold out...I've taken it to the dealer, and since it's happening at random, they could not produce the issue.
Not quite the same, but mine's been doing it year-round, so temperature is not the issue.  It's been only doing it in my driveway, that's why I'm thinking that someone is messing with it.
Next time it does it, fold them and then unfold them.  You may have someone messing with it/them, like mine.
No, not quite the same and the temperature definitely isn't the issue, though I'm sure it gets cool in Cali. We've had a rather ridiculous swing in the thermometer here as of late. 50's one day, then 3 days later wind chills of 5 to 10 below. Do you know of someone who would do it just to be funny? Touching another mans truck without permission should be punishable by law.
Edited by Jetmek
YIKES!!!  Last week, I was using the hell out of my heated sweater (mid-30s to mid-40s), with wearing a sweatshirt on my way to work (mid-60s).  This week, I haven't used my heated sweater, yet.  70+ coming into work, and mid to upper 40s on the way home.  Although, Thursday, LAST WEEK, we had high winds and it was in the 30s, when we went home.  Had my heated sweater on high, I was nice and toasty, until I cleared the hangar door.  Wind blew ALL of the heat out of my sweater, even with my gortex jacket on, over top of my sweater.
Touching another man's truck without permission should be punishable by death.
Had the same issues with passenger side not folding. It was an intermittent issue. Finally it quit all together after about a year of sometimes working sometimes not. Dealer replaced the entire mirror advising it was a bad mirror motor.
My passenger side tow mirror does this as well - when I pull out of my heated garage drive to work in the morning park hit the fold it either doesn’t go or only goes partial. I have to cycle it a time or two for it to fold all the way in. We have similar temps in the frequently below 0 and then in the low single digits or teens.
OP - you can get an adequate quality infrared game camera for about $50 from Academy/Dicks/etc.   SD card download to your phone/computer.  Your question will be answered.
Just went to the dealer with this same issue(passenger side mirror randomly won't unfold). they updated the seat memory software ,but could not replicate the problem. I don't know if it worked yet...
Been thinking about that, dash cam (motion sensitive), or camera system on my driveway/house.  I have a "driveway doorbell" from Harbor Freight, in my garage, been thinking about putting that up, too.
  • 3 months later...
I'll bet you the little plastic spur gear inside the drive unit is broken in half or missing teeth.  Ive seen this happen alot and depending on how the gear is oriented, sometimes it will grab the mating gear and sometimes it will just let the motor spin.
The real problem is that plastic gear itself, it should be metal.
You can buy the upgraded metal components here, its the 1st item.  If you have power folding mirrors, this is a smart upgrade because even if you dont power fold them much, all it takes is 1 manual fold cycle from the guy at the car wash and that cheap plastic gear usually goes snap.  Once that plastic gear in there breaks, the mirror main spring doesnt get compressed and it lets the whole mirror wobble and vibrate as you are going down the road.
http://www.gruvenparts.com/shop-by-car/gm-truck
this is good to know.
thanks
    • Rise more slowly?  Debatable.  It would run slightly cooler, yes if anything after adding the thermostat delete kit from PPE.   PPE makes a larger front aux cooler which they "claim" will lower temps 45 degrees but I have not used it.     IMO, especially in cold states, I would not want to mess with the first cooler, the oil to water one.  Cold states, you want heat in the transmission for it to shift properly, and you don't want moisture in the ATF.    Ideal temps for automatic transmissions to do their job the best is 175-220F.  Hotter than 220F you start heading towards fluid degradation and shortened fluid life/service intervals.  240F can start varnishing things like the fluid, clutches, etc.
    • FYI, I used sq body headers on my 72 and they were a perfect fit with zero clearance issues with the rods and Z bar for the clutch  I agree with post on worn mount rubber
    • I do most of my yard work before 10. My summer walks are usually at Kroger’s. Inside and yes I’ll do light shopping. Usually by noon you don’t want to be outside from June to September. The mail box is a good walk. I’ll walk there about 3 times before the mail comes. My house has two floors if I feel I need to move I’ll do the stairs. I’ll walk down the lane to our rent house with clippers trimming branches along the driveway. There’s always something to do.
    • There is a sign at my chiropractors office that says, "Don't quit, take a break." Sound advice.    On a 65 degree day (F) I can still work pretty darn hard (I'm 72). On a 85 degree day with a good deal of humidity it takes me three days to do what in took at 65 degree in three hours. If I work to muscle exhaustion (back) it will take me days more to recover. Taking breaks to prevent that is most useful. A lift belt has been very useful in preventing both.    Minister was giving a talk the other night where he was speaking of age and he used a clock to illustrate the human lifespan and it's ability to task. 1 to 45 was the second hand, scurry about. 46 to 70 the minute hand. Slower but...71 and up the hour hand...Hummm....until that talk I felt more like the minute hand. 😭   Then he says, the most useful hand on the clock is the hour hand. Without it you can't tell time. (Hour of the watch). I felt a bit better knowing we over 70 are useful. 🥹
    • I still do oil changes on our 2 vehicles and my motorcycle. I have a robot mower for the yard but can't use it in my backyard because my wonderful dog keeps digging the guide wire up so I have to push mow it. Not much of a walker especially during the summer, just to hot. I will ride my e-bike almost daily which helps to keep my knees and hips loose and helps with my balance. That's my story an I'll stick with it. We have been in the mid to high 90's with a feel like temp of 105 to 109 for the last month with no rain. We finally got some rain which cooled it off but were still stuck with the humdity. I do pace myself and that's why it takes me 2 days to do something that used to take a couple of hours.   Peace
