Prospect62 Posted February 8, 2020 Posted February 8, 2020 On 10/5/2019 at 4:23 PM, Bash74 said: Have the dealer take a look at the in tank fuel pump. I was there when they pulled my out and it was falling apart. Contaniments end up in the whole system and messes up injectors and high pressure fuel pump. Mine wasn't the first one to be like this they had to deal with. So now when injector is a problem it's the first part they check as part of diagnosing. My fuel pump, high pressure pump, rails, and injectors all replaced. My warranty covered it all. Sent from my SM-G935V using Tapatalk This is distressing.
Brownie931 Posted June 28, 2020 Posted June 28, 2020 I’m having an issue now with my 2015 Sierra. Code reads cylinder 5 misfire. I’m at 118,000 km. It’s not considered power train so no warranty. The quoted me 1890.00 plus taxes for all 8 injectors. I service my truck more than gm recommendations , shouldn’t have this issue. I was thinking just to replace the one that’s bad but only $500 more to do them all and be done with them. could I save money by going elsewhere to an independent garage?
carnau Posted June 28, 2020 Posted June 28, 2020 1 hour ago, Brownie931 said: I’m having an issue now with my 2015 Sierra. Code reads cylinder 5 misfire. I’m at 118,000 km. It’s not considered power train so no warranty. The quoted me 1890.00 plus taxes for all 8 injectors. I service my truck more than gm recommendations , shouldn’t have this issue. I was thinking just to replace the one that’s bad but only $500 more to do them all and be done with them. could I save money by going elsewhere to an independent garage? Servicing your truck has nothing to do with the fuel injection system. With fuel as terrible as it is right now, If you don't put a injector cleaner in your vehicle every so often, You will have bad injectors. Just the way it is. Check out this vidoe on how to replace them and just do them yourself. I am guessing you're in Canada or something like that with km. So goto your local auto parts store, Pick up all the injectors and then goto a dealership and get the 2 fuel pipes and do it. It's an easy job. here is the problem with changing just one. You have to remove the fuel feed pipes. When you do that, They have to be replaced. If you change just 1 and then another goes out, You are just throwing money away. Those pipes can not be reused and if you try, they will leak. Trust me.. I have tried multiple times to try to save them for people. Here is the video.
chris311l Posted July 17, 2020 Posted July 17, 2020 On 9/30/2019 at 10:59 AM, TJay74 said: Eff that, $2600 is some serious up charge. The injectors are only around $65 each and are not that hard to change. I can have the intake manifold off in less than 30 minutes and the injectors changed out in an hour. The only other thing you might need would be the 2 hard line fuel cross over pipes and the intake manifold gaskets. All in parts should be less than $500 and no more than 3-4 hours of labor. Any shop (mom/pop or dealership) should be more than capable to do this work, I have done it in my garage several times now. I can't find OEM injectors anywhere. Do you have any experience with Echlin Injectors from Napa? I want to replace all 8 myself but they say I need a special sizing tool for the seals....is this true?
Dalogava Posted October 18, 2021 Posted October 18, 2021 I had the same problem but would not give up as there is no way you should have to change injectors. It took 6 months but finally remedied. I switched to Chevron fuel and used numerous fuel injector cleaners and finally "Gum Out" worked. I don't get anymore codes and everything works fine now. I also had transmission problems as with the engine running rough the transmission kept trying to relearn itself and that has gone away now too. Hopefully this helps someone as GM wanted $2700 to just replace injectors and they couldn't figure out the transmission problem. GM was figuring I needed a new transmission. 1
