am I missing out with magnuson install
jstev4610
Great info, thanks for that.  It might not have been missing, just misdiagnosed in my head as it shifted at full throttle.  It is gone, either with the computer learning shifts or resolving itself with the half tank addition of non ethanol 91, found a place to get it close so that's what I'm putting in.  I am having pat guerra tune it, I already have hptuners for use on my grand wagoneer with a l76 6.0 swap.  Was waiting on getting my exhaust figured out, just going to go ahead and have him send an initial tune then work up the exhaust with a wideband for a follow up.  The magnuson is superquiet, I'm shocked at how quiet it is.  Had to get my studded winters removed because I'm spinning everywhere for funs.
I'd stick with the 91-92 with ethanol.  In my experience, the same octane without ethanol has a much, much greater tendency to detonate than the fuel with ethanol.  The only potential benefit of non-ethanol in your truck is 4-5% better fuel mileage.  To test for yourself, compare knock retard on fuel with ethanol and then take a log on a tank without it.
The transmission is in a perpetual state of learning and with a change as big as a supercharger, it will have a lot of learning to do to meet shift targets that it previously has never encountered.
I'm hunting down non ethanol fuel before pat tunes it simply because of this note in the magnuson book that came with the blower, and thought it was likely the cause of the tune feeling like garbage and the possible misfire.  Glad to confirm it's not going to be a constant search with proper tuning.  Are you going to be moving to Coeur D'Alene since that's where you list your recurring tuning meets?
This supercharger system requires the use of only premium gasoline fuel,. 91 octane or better. It is NOT compatible with E85, Ethanol, or Flex fuels.
Ah, I can see where you would get that.  I think they are just trying to cover their bases and ensure that all possible names for E85 are covered.  The factory fuel system isn't nearly large enough to handle full E85 operation in boost.  As long as you have the headspace in the fuel system, it's great to run a few gallons of E85 mixed in when only 91 octane is available as it is a very inexpensive octane booster.
On my SS, I regularly will add 5 gallons of E85 and then fill the rest of the tank with 91 octane.  On the dyno, that was worth over 50hp compared to just our crap 91 octane alone (when tuned appropriately).
Yes, we are relocating to the CDA area and have been making quite a few trips that way.  I'll even be in your town for a few hours next week with the family to pick up a new vehicle.  :ninja:
  • 1 month later...
Jstev4610, I’m wondering if we can compare notes. I have a 2017 Sierra 6.2L 8-speed with a new Magnuson TVS 1900 on it. Black Bear Performance gave me two tunes. My main question is how much different the Black Bear tune is versus the stock Magnuson tune because I’m not getting great results/performance from the Black Bear tunes.
Tune 1 on 91 octane California pump gas:
- Quick, short-lived ping when really getting into the throttle while coasting at 20mph or so. Same thing when smashing the pedal down while already at highway speed.
- When using the supercharger hard at city speeds, the RPMs seem to just jump up and no REAL torque is produced. This is a REAL disappointment.
- In almost every situation I have to coax the supercharger to really get it to pull. I have to hit the pedal hard, let off, and then hit it hard again. It’s as if when I smash the pedal down and don’t let up, the truck won’t downshift and won’t allow torque to be delivered. When I say “smash the pedal,” I’m not talking about WOT flooring it past the click at the bottom of the pedal, I just mean giving a huge push like 80% of what the pedal can move. I don’t want to have to absolutely floor it to the bottom of the click every time I want to engage the SC in city driving.
Tune 1 on a nearly 50/50 mix of 91 and 100 octane both CA pump gas:
- Ping was nearly all gone, just barely noticeable in the low speed heavy throttle tip in.
- Still did the same thing where the RPMs would shoot up with very little response to my “GIVE ME BOOST” command. Had to let off and then get back into it again.
Tune 2 on 91 octane California pump gas:
- Ping wise, reacts almost exactly the same as using Tune 1 with the 50/50 mix of 91 and 100, but with MUCH less power.
At this point, I’m quite disappointed with this purchase, and I don’t know if it’s the supercharger, the tune, or the truck itself (torque management kind of stuff)… The response when asking for the supercharger to kick in is just not there and it’s embarrassing. I really don’t want to throw good money after bad, either, chasing down a fix.
Speaking of a fix, here is what has been suggested so far:
1) Ping wise, Tune 1 and Tune 2 could be experiencing spark blowout. Guys on Performancetrucks.net have suggested to use a colder spark plug and/or shorten the gap on the plug. Black Bear said shortening the gap won’t help, but a colder plug might. I still need to figure out what plug to use because the two problems are the NGK plugs are not the same length as the stock plugs (but the much more expensive Brisk plugs are), and I need to figure out if I should use a projected tip or a non-projected tip.
2) Response wise, Black Bear said that maybe tuning the transmission could do the trick because it wouldn’t be lugging the engine so much when I get into heavy throttle. And yes, according to Black Bear, you can tune this 8-speed if you swap in a 2015-2016 T87 TCM, which I have.
3) Black Bear suggested dialing back the throttle response in the areas of ping. That concerns me because the truck already seems like a dog compared to what I would expect it to do. Honestly, it’s not worlds better than stock to justify the money I’ve spent on it.
4) Black Bear suggested using 5gal of E85 and 15gal 91 octane. I know Justin has said it’s fine to do with non-flex fuel trucks, but it scares me a little bit and E85 is not close enough to make it convenient to use on every fill up.
5) Could spend many hundreds more on a meth kit and then have to deal with getting and mixing methanol all the time.
Until just a few months ago, my last truck was a 2006 Sierra 5.3L, 4-speed, 4.10 gears with a Magnuson MP112 on it. It kicked this truck’s ass in everything other than top end speed or highway supercharging. That truck only had 295hp stock and this truck has 420hp stock. Kinda wish I had just repainted that old truck and kept it, but how could I have known?
So Jstev4610, hopefully you’ve read this far and can find the time to write about what you have experienced with the stock Magnuson tune so we can compare.
My experience with the maggie tune compared to what you're seeing.
I had what I thought was a miss at high rpm, right before the shift point.  I think it was the tune, not the gas.  My only options are15% ethanol and non-ethanol 91.
I had to hammer it to get it to open up.  I don't know if this is because of the bypass valveing or not.  My follow up tune has kind of the same feel but much less, feels like it kicks in sooner.  I don't have to hit the pedal hard, let off, then hit it again though.  Just once, the valve opens up and it takes off.
The shifting was garbage with the maggie tune.  That seemed to be the most noticeable change.
I'm pretty happy with mine, even with the magnuson tune.  The additional hp was definitely noticeable right away.  After getting a good tune, it's fantastic and I have to be careful not to spin the tires.
Things I did before getting my follow up tune:
Long tube Kooks w/catback y pipe
Carven catback
Pulley'd down to a 81mm from 87mm to get the boost back up
It's a beast now.  I'd investigate that bypass valve setup first, then the tune.  Don't give up, it's worth it when it's working as designed.
I forgot to say that miss I thought I was feeling was gone with the new tune I got.  Still have to get a follow up on it but having problems getting a wideband to read into hptuners.
  • 2 months later...
Carven catback
Hilarious outcome on my end! All of the problems I was having were due to being sent a pulley that was too large. Magnuson sent me an 84mm pulley with the kit. The second I was able to get an HP Tuners data log and send it to them, they next-dayed me a 78mm pulley because my log showed that I was only averaging 2-3psi of boost and maxing out at 4.5psi when it should have been making 6psi. The new pulley now makes just shy of 6psi and is a world of difference. Now it feels like I have a supercharger again. It was driving like s&*t before and was quite embarrassing, but now it feels like my old truck did.
    RSTRICK
    RSTRICK
  • Who's Online   6 Members, 0 Anonymous, 578 Guests (See full list)
    • Coming back from towing a car to my daughter in Nashville truck started making a screaming noise from underneath.  Pulled over placed in park and sure enough whining noise from underneath.  Dropped at the dealer fearing new tranny or another front pump/cover replacement.  Service writer said it sounded like the tranny too...  Well $300, new idler and a belt all is good.  Pop the hood and give a listen. lol  Now I'm telling dealers I'm no longer interested in a new truck.
    • HD uses the 6.6 gas.   Oil consumption while heavy working is considered normal.  1 quart per 100 gallons of fuel is the normal rate above 8600lbs GVWR.  If more than that, it is considered excessive.   They will have to perform an oil consumption test using the guidelines in TSB 03-06-01-023J.     Information on Engine Oil Consumption Guidelines All engines require oil to lubricate and protect the load bearing and internal moving parts from wear including cylinder walls, pistons, and piston rings. When a piston moves down its cylinder, a thin film of oil is left on the cylinder wall. During the combustion process, part of this oil layer is consumed. As a result, varying rates of oil consumption are accepted as normal in all engines. Oil Consumption Oil usage has a direct relationship with the amount of fuel used. The harder an engine works, the more fuel and oil it will use. Therefore, oil usage as a factor of fuel usage is a more accurate indicator of acceptable oil consumption levels than vehicle mileage for vehicles at or above 8600 GVW. The accepted rate of oil consumption for gasoline engines in vehicles at or above 8600 GVW is 1 liter (1 qt) within 400 liters (100 gallons) of fuel used. This rate only applies to vehicles under warranty, maintained in accordance with the appropriate maintenance schedule, driven at legal speeds and within design intent of the vehicle. Many factors can affect an owner's concern with oil consumption. Driving habits and vehicle maintenance vary from owner to owner. Thoroughly evaluate each case before deciding whether the vehicle in question has abnormal engine oil consumption. Gasket and External Leaks Inspect the oil pans, engine covers, and the engine oil cooler for leakage. Inspect for oil leakage into the engine coolant. Improper Reading of the Oil Level Indicator (Dipstick) The vehicle must be parked on a level surface to obtain accurate oil level readings. Verify that the dipstick tube is fully seated in the block. When checking the oil level, make sure the dipstick is wiped clean before taking an oil level reading and fully depress the dipstick until the shoulder bottoms out on the dipstick tube. The dipstick should be the proper part number for the engine/vehicle that is being checked. Not Waiting Long Enough After Running Engine to Check Oil Level The vehicle should be allowed to sit for at least 15 minutes, after the engine has been shut off, before taking an oil level reading to assure the oil has had enough time to drain back into the crankcase. In order to ensure accurate results, the temperature of the oil should be close to the same temperature as the last time the oil level was checked. Improper Oil Fill After an Oil Change Following an oil change, verify that the proper amount and type of oil was put in the engine and that the oil level on the dipstick is not above the full mark or below the add marks. Refer to the Owner's Manual or Service Manual for information on recommended oil quantity, viscosity, and quality. High Speed or High RPM Driving Continuous driving at high speeds/high RPMs may increase oil consumption. Because this may not always be an everyday occurrence, it is hard to determine exactly how much the oil economy will be affected. Towing or Heavy Usage Towing a trailer or hauling additional weight will increase oil consumption. Large frontal area trailers will further increase the work required from the engine, especially at highway speeds, and thus increases the rate of oil consumption. PTO Operation Operation of a PTO will increase fuel and oil usage, as the PTO driven accessory uses engine power to operate. Crankcase Ventilation System Verify that the positive crankcase ventilation (PCV) system is operating properly. Blockages, restrictions, or damage to the PCV system can result in increased oil use. Oil Dilution from Condensation On vehicles that are usually driven short distances, less than 8 km (5 mi), especially in colder weather, condensation generated from cold engine operation may not get hot enough to evaporate out of the oil. When this occurs, the dipstick may indicate that the oil level is over-full. Subsequent driving on a trip of sufficient length to enable normal engine operating temperature for 30 minutes or more, in order to vaporize excess moisture, may give the customer the impression of excessive oil consumption. Engine Temperature If an engine is run at overheated temperatures (see Owner's Manual or Service Manual) for more than brief periods, oil will oxidize at a faster than normal rate. In addition, gaskets may distort, piston rings may stick, and excessive wear may result. Verify that all cooling system components are in proper working order. Engine Wear Piston scuffing, excessive piston-to-wall clearance, tapered or out of round cylinders, worn, damaged or improperly installed valve guides, seals and piston rings will all cause an increase in oil consumption. Measurement of Oil Consumption Engines require a period of time to BREAK IN so that moving parts are properly seated. Therefore, oil economy should not be tested until the vehicle has accumulated at least 6400 km (4000 mi). An exception would be allowed only if an engine is reported to be using more than 0.946 liter (1 qt) in 1600 km (1000 mi).   Verify that the engine has no external leaks. Repair as necessary. Verify that the engine is at normal operating temperature (see Owner's Manual or Service Manual). Park the vehicle on a level surface. Wait at least 15 minutes, after the engine is shut off, before checking the oil level to make sure that most of the oil has had time to drain back into the crankcase. Check the oil level and record the vehicle mileage, date, and exact oil level on the form included in this bulletin. Next ensure the oil level is at, but not above, the full mark on the dipstick. add oil if necessary. Also ensure the proper viscosity and quality oil are being used as recommended in the Owner Manual Ask the customer once they have consumed 100 gallons of fuel schedule an appointment and return to the dealer for inspection. If the final evaluation shows that the engine uses more than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, follow the published symptom diagnostics as described in the appropriate Service Manual. If the oil consumption test shows that the engine uses less than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, explain to the customer that their engine meets the guidelines for oil consumption.
    • I have a 2024 Chevy Silverado 2500 with the 6.2 liter engine, Vin: 2GC4YME79R1273849, with 27,437 miles. Recently we took a trip from Candor, NY to Townsend, TN pulling our fifth wheel, when I got close to the Townsend, TN area The truck gave me a message of low oil. I checked the dip stick and found it was 2 quarts low. Today, August 27, 2026, I had the oil changed and the technician Found the truck was very low on oil.  Is there a Recall for this? What is my recourse for this issue? Do I call the dealer where I bought it or any chevy dealer?   Robert Strickland 292 Owego Road Candor, NY 13743 352-502-6588 [email protected]
    • We understand the importance of understanding how your Sierra performs, @SoCal Angler. Our team would like to gather the proper details to assist you with your inquiry about your truck's automatic braking. When you have a moment, please visit: https://s.chevy.com/support-request and fill out the request form with pertinent details. This will ensure your request is routed correctly so we may take a further look. We will keep an eye out for your outreach.
    • That is the funnel kit I bought and for being here in Canada I did get a better deal than what other sources were charging through a certain supplier in town that sources more directly and they ordered it for me. There are other items now on the market which would be perfect as well but this has worked well which was the hope when I bought it. I mentioned the Amsoil quart bottles as they have that squarish shape up top and it props nicely on the rim of the opening without falling into the funnel so I can leave them sit and drip a bit. You may have already figured out that to get the cap off the valve cover unless one is 7 + feet tall its not going to be reached without standing on a step of some sort and so when I do that I put the right adapter in and just leave the elbow on the funnel all the time anyway and open the lid and then if using quart containers for sure I can stand beside the truck and leisurely add the oil, and I can leave that funnel on when starting the engine to let it idle to fill the filter and then add the rest of the oil to top it up before removing the funnel and putting the factory cap back on. I put the cap back on the top and slide the bottom cap on as it fits onto the elbow adapter also and then store the funnel in a clean household plastic garbage bag along with the adapter so I have no reason to be washing out the inside of the funnel as I keep it completely clean between uses.    Draining the oil as per the under the truck portion, yes indeed that is slick as someone was thinking on GM's part there and admittedly I don't drop the oil screaming hot in this truck due to the exhaust being there and makes it safer as far as the oil temp if its just warmed up some instead as I don't have the truck on any ramps etc as I do it as the tires sit on the garage floor. The filter is not boiling hot then either and can drop it off into another pail after pulling the drain plug and just leave it drip out. Go back under a few hours later with new filter in hand and clean off the filter base and put the new filter on and install the drain plug. The filter is a little cramped in there as per wrapping ones hand around the filter and I am so used to using the band style filter removal tool that its no big deal and same for snugging it up. My filter wrench is many years old now but I think this is the current version and sounds like the right size, just in case my explanation was not great ( those nylon strap wrenches that one tool fits all filters are not my favorite tool to use, I much prefer this style personally )     57020 Swivel Gripper - No Slip Filter Wrench - Small | Lisle Corporation   And again about the oil draining and filter setup under these GM trucks, I've watched Ford videos of them struggling with oil flying sideways out of the oil pan on the gas 7.3 due to the sideways drain plug onto other components or cross members and guys trying to make shields out of carboard etc and other Ford pickups that Ford insisted they have sideways drain plugs. One win for GM there anyway with this engine.
