i am having trouble with my 2010 chevy silverado. after someone installed an aftermarket radio  i noticed that my dash lights radio lights and hvac lights all stay on all the time. i assume a wire shorted out somewhere but i cannot seem to find anyone that has had this problem before. i checked ALL the fuses. all good. pulled fuse block to make sure all under wiring was good. check out ok. replaced the dimmer switch no luck. i did find that one of the only way to get them off besides unhooking the battery is to unplug one of the clusters from the BCM. i was leaning on it being BCM problem but if it was wouldnt i have other issues with the truck? the other way is if i unplug one of the cluster on the back side of the left IP junction block. i have read a ton of these threads and have yet to see anyone with this issue. most issues i see are the dash lights dont work at all and this is not the case. every works fine. o i also took the aftermarket radio out and still lights on. i put the factory back in and still have this issue. PLEASE PLEASE PLEASE someone HELP
EDIT forgot to mention also replaced ignition switch. no change
Edited by bbunch32
left out info
Sounds like a wring issue from the new radio. Lots of installs tap wrong wires or screw grounds
i took the aftermarket radio out and even with no radio in the lights stay on. i installed the factory radio and still have the same problem. i looked at the aftermarket harness and i did see that he wired the illumination wire to the acc wire. im not a radio person but that dosent see right to me. but what i dont get it why even after the aftermarket radio was taken out why do i still have this issue.
im pretty sure he shorted a wire because  before i had the correct harness he told me that he would just hard wire it in. i believed him because he installed radios for a living. while he was fiddling with wires i did some research and read that its a bad idea to cut the factory harness out. i told him i wanted to just buy the correct harness. well when i returned he joked about popping a wire. he told me that they take a 9v battery and touch the speaker wires to the battery and it makes a buzzing sound. now i know nothing about electrical but this all sounded completely stupid to me and so i told him that i didn't need his help any longer and he wired the harness up and i plugged it in and all was well. until i noticed that my dash lights would not go off.
i am having trouble with my 2010 Chevy silverado. after someone installed an aftermarket radio  i noticed that my dash lights radio lights and hvac lights all stay on all the time. i assume a wire shorted out when i had someone install the radio. long story short i caught him with a 9v battery touching wires to it. he said he was trying to locate which speaker was which. i bought a harness and he used it. but i also noticed after i pulled it out that the illum wire was hooked to the acc 12v wire. i do not believe that was right to do.  i checked ALL the fuses. all good. pulled fuse block to make sure all under wiring was good. checked out ok. replaced the dimmer switch no luck. even with the new dimmer switch i notice that it dosent always dim. most times it works but there are times where i get curios while driving and find its not working. i did find that one of the only way to get them off besides unhooking the battery is to unplug one of the clusters from the BCM. i was leaning on it being BCM problem but if it was wouldn't i have other issues with the truck? the other way is if i unplug one of the cluster on the back side of the left IP junction block. i have read a ton of these threads and have yet to see anyone with this issue. most issues i see are the dash lights don't work at all and this is not the case. every works fine. i also took the aftermarket radio out and still lights are on. i put the factory back in and still have this issue i also replaced the ignition switch and this did not help my issue. can you offer and solution?
  • 4 years later...
What was the solution?
I have a 2012 Silverado - 3 days ago the parking lights wouldn't go out - pulled the relay they are off.  Tried other relays and same issue - won't go out.  Now today my instrument panel lighting will not go out.  A remote start was installed 3 months ago so I don't think that would be the issue.  Everything else is factory.  The last couple of years the radio lights intermittently don't work - the clock portion will go out and/or the stations along the bottom are not lit.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
