10 hours ago, Homewrecker007 said:
You can use your factory switch. I believe the titan window is $600 on its own.
It just occurred to me to to ask: is there a range of years for the Titan that are better to use than others for the rear window swap?
The one I used was from a 2006. Pretty sure they are from 05 to 13. Least that what the nissan website says for the part number. There are a couple windows on ebay atm for 200-300. Then have to find the motor and regulator.
The big thing was sanding down the plastic edges on the inside for the window to sit flat.
On 6/28/2024 at 10:09 PM, DANS_NBS_SIERRA said:
I took a switch out of a avalanche and plastic welded it to my factory ceiling console so it looks factory.  When I get my day off on Sunday I'll send pictures and what not.
I ended up going with using the bolts on the factory window. Cut out the inner part of the cab. Cleaned it up and under coated it.
Like I said before I'm just trying to help everyone out and not get rich off of this stuff that anyone can make or have made.
It would be great to see some pictures of your install. Also, thanks for letting others know of your experience with the kit that was previously recommend. Hopefully others will listen and not get burned.
Edited by UrbanRage
1 minute ago, UrbanRage said:
It would be great to see some pictures of your install. Also, thanks for letting others know of your experience with the kit that was previously recommend. Hopefully will listen and not get burned.
I 1000000% want to see his drip pan improvements. 😁
Thanks for the pics, Dan.
Where exactly does this drain to?
Is there a hole in that part of the floor or something?
I drilled 3 holes, one under each guide where the window rides and one in the center. They all drain to the ground under the cab. Then under coated it all. Trying to work on a legit drain trough with two 3/8th tubes that would run down and out.
Thanks for posting pictures. I can definitely see the difference between the two pans. If you wouldn't mind keep posting pictures as you continue this install.  The larger window is a huge improvement over the factory GMC window.
10 minutes ago, DANS_NBS_SIERRA said:
yea most def not worth 300 bucks if you ask me.
I'm going to order some carbon fiber panels and see if I can make something that's nicer and stronger at work.
53 minutes ago, DANS_NBS_SIERRA said:
My father in law has a sheet of carbon fiber that's about 1/4 inch thick. I thought about that the first time before going aluminum. But with the carpet and what not it will never be seen.
If I make a carbon pan, I'll clear coat it and make sure everyone can see it. 😁
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 600 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
