Only 2.5 volts reference to map sensor
2003 gmc sierra 2500hd. 6.0 auto.
I have an issue I can't figure out. The truck doesn't want to run . It just starts and dies. Throws code p0107 (map sensor circuit low). I changed the sensor with two different ones with no change. I checked the wires between sensor and ecm with multimeter and all wires are good. I only have 2.5 volts reference coming out of ecm to gray wire on map. I changed the ecm and the voltage is the same. I don't know what to do now.
Only 3 components for the map sensor. PCM, sensor and wires. Did you check the voltage at the ECM? Conn 1 term 48
Yes I checked it at the wire where the pin goes in ecm. Only 2.5 with two different ecm got the same reading. All other components are getting full 5 volts.
At the wire where the pin goes into the ecm? It should be checked at the MAP end of the harness first. Only one of the 3 wires should be live (key on). If voltage found on other wires, then likely a short. If not 5v, then either a short or bad ecm. Check pin at ecm to confirm 5v.
When ever checking v, check against a good ground , ie battery negative. Do not check against supposed ground on wire harness. Once volts confirmed on wire, then check against supposed ground wire to confirm that ground connection is not a problem.
Sent from my Moto G (5) Plus using Tapatalk
My tuner led me to the problem. The oil pressure sending unit shorted out and grounded that side of the ecm. Unplugged the oil pressure sending unit and immediately got my 5 volts back to map. Runs like a top. Thanks for the help guys. Another one solved.
