Do my kids count as rodents?  Filthy animals...
  • Haha 3
So, to chime in on this,
My truck was 2 months old and I had about $1000 worth of work from the dealer taking a part half the dash and cleaning up the damage after rodents ate my cabin air filter and made a nice nest. chewed up some stuff etc...
I did what another poster said and put in some steel wool around the windshield cowl area. (my dad who has has a GMC said his dealer told him to do this).. I also took some screen mesh and cut it to the size of my cabin air filter. once I inserted the filter, I placed the mesh in on top of it. to keep any rodents from chewing up the filter.
So far it has done well, we will see this winter since that's when the last time this happened. I think they want a warm place to go so they head up in there but I have no idea. I live in Maine, and the first time this happened was in January with snow and negative temperatures.
  • 2 months later...
It’s a shame to spend that kind of money on a new truck and have to deal with problems like this. I’m on my fourth filter with only 24k on truck. After doing some research on this I found there can be a major problem with breathing that horrible odor it called hantavirus pulmonary syndrome and can be fatal.the factory will do nothing to help.
Edited by R Jandura
On 6/3/2018 at 10:20 PM, Stihl3500 said:
The mice are coming in from under the windshield cowl. Take your windshield wipers arms off and remove the plastic cowl under the wipers. There are a few plastic clips and disconnect washer hose and radio antenna. Once that is removed on the passenger side there will be a plastic access panel that is siliconed on. Remove that also. There is no protection to keep rodents out of cabin air filter. Once you are in there u will see what I am talking about. I had a nest in my filter twice. Today I made a screen out of galvanized metal today and used aluminum hvac tape to secure it. I should keep them out now. I know it sucks to have to do this to a new truck but it is poorly designed with no protection. Hope this helps
How difficult is it getting the cowl off? Any advice or tips appreciated
On ‎11‎/‎2‎/‎2018 at 5:56 AM, Midnight Black said:
I get a lot of calls with issues like this, and they have turned into 15k worth of damagaes to their main wiring harnesses. All the home remidies unfortunately will not work. You need to park In A garage if at all possible when the rodent pressure is high. If you can’t park inside, the best defense is poison stations next to your tires and around any outbuildings. Yes this will be a pain to move them every time you take off and park, but better than mouse damage.
Mice have no problem getting into my garage but Louise da Cat keeps the population in there to zero the last three years. A mouse trap in the cabin with peanut butter bait gets any that get by her while she's out killing rabbits or the neighbors dogs. That is one mean cat :rolleyes:
  • Thanks 1
  • 2 years later...
On 7/13/2018 at 6:00 AM, Yeti1007 said:
Lol, then I'd have to get Dogs to get rid of the Cats so on and so forth
And lions to get rid of the dogs, elephants to get rid of the lions, and mice to get rid of the elephants.
Good luck.
  • Haha 1
Do you have access to slag from a metal facility? I live in Saskatchewan and we have Evraz in Regina that you can buy slag in 0”-3/4” and to 2”
lots of people use the 0-3/4” for making parking pads. Once you pack it and it rains a couple times, it sets up like asphalt. Also use it as a perimeter around buildings rather than crushed rock. Its really abrasive and rodents wont walk across it.
i did a huge pad for parking trailers and vehicles on in my back lot. Also used it around my shop.
i used the larger stuff in my maintenance free flower beds. It stays a nice blue/grey color too.
but them little f*ckers wont cross a 4” wide strip of it. Its like walking on glass and razor blades to them.
havent had a mouse in a camper, enclosed trailer, boat, truck or shop since.
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,533 Guests (See full list)
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
