Went out to the truck this morning, hit the unlock on the key fob, and the horn and lights went off a bunch of times.... like the alarm was going off.
I'm thinking weird... so I get in, fire up the truck, start driving away, and the DIC is flashing "theft attempted"
What the heck is this all about?? There's no signs of any attempt on the doors, will someone just lifting the door handles do this??
Sent from my BBD100-2 using Tapatalk
So weird.... Zero signed of any attempt
Very strange, same with my 2019 2500hd.... Truck in the driveway and horn starts beeping. Done this 3 times over the weekend. now my truck will not start via key fob nor My Chevy APP.... Any suggestions or solutions??? Only 14000km's on truck.
Did you ever figure it out? Happened to me once, but my door actuator went bad and would only lock manually, one morning I got in the truck realizing I had forgot to lock it manually but still had locked and set the alarm via key fob, figured someone came by and opened my door during the night. Truck was a 2015 Silverado
Nope.
if it's under warranty get it in to start a record of the issue.  They probably won't be able to do anything but give it a try.
Hi all.  I have a 2019 2500HD and am having the same issue.  I work at the proving grounds and talked to some of the techs there.  My issue was caused from the hood switch being dirty.  Try spraying it with contact cleaner.  The BCM is getting a false signal that the hood is being opened and thinks it is a theft attempt.  Good luck!!
I don’t have an HD, but I too recently had issues with “theft attempted” messages, my panic alarm going off randomly, and eventually “hood open” warnings in dash. Dealer replaced my hood latch and all went back to normal. The more I read on here, the more posts I saw about issues with the hood latch sensor, some people even we’re trying to bypass the sensor altogether.
  • 3 years later...
I’m having the same problem with my 2019 Equinox first time it showed theft attempt but everything worked properly then the next day the open hood message was on so I cleared that and ordered a new latch with switch yesterday. Today the alarm was just going off so I looked on the dash and it showed theft attempt so I unplugged the hood sensor and  no alarm so far.  I haven’t been able to remote start since this problem started and the only fault code I’ve been getting is hood open sensor
    RichardRS
    RichardRS
  • Who's Online   2 Members, 0 Anonymous, 785 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
