The new 2019 1500 Silvie is 450 lbs lighter. Does that equate to roughly 100 less lbs per tire?  Is that going to cause a little lousier traction?
Jim
17 Silverado
I never had any traction trouble in my 2000 Sierra and it's about 500 pounds lighter than my 2015 Sierra.
Good tires you’ll never know the weight ain’t there.
Best vehicle I’ve had yet (and yes I’ve had a sh!t load) in snow and mud was a 4x4 square body S-10 blazer with the 2.8L and Copper A/Ts. The only way to get it stuck in snow was to get it high centered. Mud it was light enuff to “float” over most anything.  Anybody that’s owned a S-10 will tell you they don’t way anything.
