Can't burnout
1 hour ago, Chevybass said:
Tire size is stock for the 18in rim option. I'm running dynapro atms. Not sure what rear end I have but I know in running 3.73 gears
Check your RPO codes in the glove box if you see what that says G80 then you have a G80 locker and word of a advise they are a low designed for low speed and you CAN damage them your rear end...
  • Replies 38
If you have a 3.73 you probably have a max tow truck and that means G80.... Burn out if you want to find out what the insides of your rear end look like laying outside on the parking lot... G80's are not meant for doing burnouts, they're low speed traction devices, burn outs are their blood enemies...
Old video but still true since the design of the G80 Eaton locker has remained the same since its inception.
All those paws, pins, etc are not meant to hold up to repeated high speed burnouts. It will be ok for a few but burn out often, even on gravel, and BOOM!
That said I have a 97 k1500 with 14 bolt semi float rear axle and G80. Over 200k and no problems. Never done a burnout but lots of G80 engagements in snow and off roading. These were all low speed engagements, not full throttle trying to burn out.
If you want to do burn outs you kinda need an LSD not a Locker....
I had a rear end go out once. I used to burn out, off road mud bog'n, driving through deep salt water that was above the vent tube, etc. One day I noticed that the vehicle was "surging" as though someone was lightly applying and then letting up on the brake when I was driving. I pulled over and check everything under the rig visually. When I got back int he rig, it went forward about a foot, and the rear tires locked up. I backed up about a foot and the rear tires locked up. I could only drive forwards and backwards one foot! Well, sometime ya got to do what ya got to do. I put the transfer case in 4 low, dropped the transmission into 1st, and floored the shit out of it. KA-BANG! The rear end blew up. I put it in 4 high, and drove it home. It sounded like a handful of rocks inside a coffee can, inside of a clothes dryer. By the time I mad it home, there were several puncture holes in the differential case, and gear oil was leaking out everywhere. I traded a used vacuum cleaner for a complete rear axle out of another truck. Bolted it up and I was good to go.
Not a burn out but when I purchased my truck new I could never get the rear tires to break loose for a few seconds when I mashed the gas.
Had Justin at Blackbear tune it for me and remove some torque management.  What a difference.  You just can't beat a personal tune. Now if I mashed the gas the tires will break loose for a few seconds and away I go.
Not a burnout but at least I can tell I'm getting more power to the ground now.  Not bad for an such an old 5.3 compared to today's new power-plants.  Also this was with factory size tires and running BFG's K2 A/T's
same here my trucks tuned and all that fun stuff, no need for brake stands it burns out just touching the gas. but mines built.
I guess I do have the g80 lol.  I guess I won't try to do burn outs. I can chirp the tires and it chirps in 2nd gear sometimes. Has decent amount of balls but oh well guess I'll get me another camaro for the burnouts later. lol
    JohnRoy
    JohnRoy
  • Who's Online   5 Members, 0 Anonymous, 646 Guests (See full list)
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
