Yeah you can swap overlays back and forth. As long as you have a diesel since the tach only goes to 5k on the diesels and 6k on the gas. If you use a diesel overlay on a gas you might have some indicator lamps in the wrong spots too.
Thank you,
I just stumbled on a set of overlays with the 5K tach.  Now if only i could locate the servos with the correct color LED's.
Yeah the servos are a little harder. If you can find a bricked cluster with them for cheap they will still work too.
Just grabbed this one off eBay as my donor cluster. $200 for this one.  Guess i could put it back together with the Red leftovers and sell to someone.  Might be hard since the rest of the trucks will be blue back light.
I attached a picture, would this work as a color donor to swap from red to blue on a 2016 denali cluster? Or is a 2016 denali cluster already blue? Idk when they changed from red to blue in the denali?
The 2016 Denali clusters are RED and from what I read in this thread the cluster overlays you have pictured will NOT work in a Denali cluster.
So if I order a cluster for my 2015.5, it will be all red, and work after Chris programs it. At that point I still need another Denali cluster to switch to blue? So a 2017-19 denali cluster, or can it be a truck that isnt a denali but like an slt or sle model and still work?
Yup. And has to be a denali. Or parts from a 17-18 Denali cluster.
Edited by RACERX7775
Corwest,
Is there a trick to removing the needles?  I pulled gently but wanted to ask before I caused any damage what the proper procedure is.
Thank you,
1 hour ago, RWaddell said:
Corwest,
Thank you,
****I played with it a little longer and figured it out.
Actually since I sourced a cluster to get the overlays and the servo boards I should just be able to unplug the servo board and switch without taking the overlay off correct? Can you tell me how this connection comes apart so I do not destroy it?
Thank you,
Edited by RWaddell
Interesting mod.  I’m waiting for my cluster to get in from Chris now.  I’ve already got the hvac, lights, and 4x4 switch from a Sierra for under 40...  I’m wondering if I can just get the less in my radio swapped over for the skip pause play. I like the red much better.  Grew up gmc and Pontiac and this is my first Chevy.  I pulled apart my old HVAC unit and man that was fun to say the least.  Looking at the board those LEDs are in there really good.
Barman, Same here. My cluster should be here on Tuesday. I was lucky to have traded my Chevy blue switches for the red GMC switches from another great member here. We traded our screens as well. So I have all red, he has all blue. Except for my ORL headlight switch, which is still blue.  I cant wait till my cluster is installed.
Side note... anybody here have the red ORL headlight switch that might want to trade for blue?
  • 8 months later...
I have 2014 Silverado but did the whole hmi/radio module retrofit to gain AppleCar and AndroidAuto with 2017 Denali cluster 2017 hmi2.5 and 2015 radio module everything programmed by WAMS Every is perfect
So you were able to get a 2017 Denali cluster with the blue graphics in display with a 2014? Interesting. Ill bet all that cost a pretty penny though.
Mine is a 2014 I have a 2017 hmi with navigation and 2017 Denali Cluster blue in my truck357AD890-B62F-4906-B48A-621E09CA1D39.thumb.jpeg.9e1301cba29c3f4337086027abeab251.jpeg000ED315-B601-410D-AD31-A2DDEF6993F3.thumb.jpeg.41420c2cfe40adcd962c1ef3fcceb9f3.jpegFA46B448-29C0-4624-8261-D7D204BA6E6C.thumb.jpeg.aa6f2742d86388dbddf374b4560b1005.jpeg
Edited by Frankielozano214
    • Still $3.01 with even more places at this price
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
