2018 SLT & Denali cluster
7 minutes ago, TXGREEK said:
I’d like to know what the new part costs and when you say it was easy to install, approx time too?
The cluster is about 450.  To remove it you pop h4 trim off around the steering wheel. That's a whole 20 seconds. Then lift the dash peice in front of the steering wheel off. (Clips) then undo the 7mm screws from the cluster itself. There may be 1 more step or bolt I'm forgetting but that's it
Is it just a plug and play type and did you get yours flashed for an SLT, can you do that, does it still say Denali?
I havent gotten mine yet but I've been speaking with phil.  You buy the cluster and have it flashed for your vehicle. It just plugs in
I have a silverado. And I'm getting the Denali (blue) cluster
On 6/17/2018 at 4:47 AM, ryce4u said:
Hey Guys ! I just bought a 2018 Sierra 1500 SLT Black on Black premium plus package 6.2L V8 4wd tonight . It's my first time owning a truck. I've always own 2 seaters sport cars and thought it was time to own something more practical for raising a family. I've read that the Denali has a digital cluster and was reading up on doing a swap. Is it me or the 2018 Sierra 1500 Denali Cluster look very similar to a 2018 Sierra SLT cluster ?? Is it even worth doing a swap if the two clusters look this similar ? Does anyone have the part number for a 2018 Sierra 1500 Denali cluster ?
Pic for reference :
https://www.sterlingmccallbuickgmc.com/VehicleDetails/new-2018-GMC-Sierra_1500-Crew_Cab_Short_Box_4_Wheel_Drive_SLT-Houston-TX/3206491543
https://www.sterlingmccallbuickgmc.com/VehicleDetails/new-2018-GMC-Sierra_1500-Crew_Cab_Short_Box_4_Wheel_Drive_Denali-Houston-TX/3207084093
http://www.rossdowning.com/VehicleDetails/new-2018-GMC-Sierra_1500-Denali-Hammond-LA/3234700723
Try using the Search field in the upper right corner.  There are a bunch of threads on here already (2017_whitez71 linked to one above)
Whatever you do make sure you get the new cluster programmed by Chris White BEFORE you install it in your truck or else you will brick the cluster and it won't work.
If you have a 2016 like your sig says than you need the cluster from a 2016 Denali.  I don't think Sierra changed to the blue until 2017.
The thread that 2017_whitez71 linked above has all the correct part numbers that will work for your truck.
Phil has a 16 silverado with blue cluster. i have the part numbers. im good
  • 1 month later...
I’ve been watching Ebay for a 2018 Denali cluster PN 84385167.
WAMS charges $100 more for programming a used cluster vs new. So been looking for new.
Best set price I can find online for new is $389 + $17 shipping.
https://www.gmoutletparts.com/p-cluster-84385167
Anyone find a better price?
    mighty K20
    mighty K20
  • Who's Online   2 Members, 1 Anonymous, 455 Guests (See full list)
