Brake hose compatibility
So on my nbs i swapped hydroboost and still have the vacuum brake hoses and the one is bad. I also swapped to the nnbs larger calipers. My hydrobooster is rated for 12,000 lbs and the escalade one is only 7,200 lbs so which brake hose can I run? Will the 3500 HD brake hose bolt into a 1/2 ton caliper?
