Debadged truck pic request
  • Replies 84
  • 1 month later...
Took all the lettering off, fully blacked out bowties, left the special midnight edition z71 badges alone because I like how they look and help tie my brake lights and calipers together with the red.
Hate the work, but debadging is always one of my favorite mods. 74f38df70f7dc6de60d0c813de3e6458.jpg
Sent from my SM-G955U using Tapatalk
20181021_184626-1589x1191.jpg.a84466b0dbea84e36070a68613ff92d7.thumb.jpg.a9bdaef81be77e11589ffd2cf2e88248.jpg
Not to derail the debadge theme, but can you offer me some tips on doing the bow ties please? Last time I tried to wrap them idk what I did wrong, but it did not work out at all.
The center was already black since mine is a midnight,  then I took the easy way out and had the shop that does my tints use a commercial version of plasti dip while it was there for 20 bucks.  Actually had them do the steering wheel bow tie too.  I'm no painter so I leave that to the pros :)
The center was already black since mine is a midnight,  then I took the easy way out and had the shop that does my tints use a commercial version of plasti dip while it was there for 20 bucks.  Actually had them do the steering wheel bow tie too.  I'm no painter so I leave that to the pros [emoji4]
Thanks for the quick reply! At this point I'm probably gonna go the professional route too lol
Although I've seen my cousin use painters tape and plasti dip to do bow ties and lettering and it really doesnt seem too bad since you can peel it right off if you over spray.
 DeBadged 2018 Midnight Edition.  6.2L, 3" level, 33" duratracs, muffler delete.
Look's Good . wish mine was that clean
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 230 Guests (See full list)
