Need some help here folks.  I am looking for quality waterproof LED strip lights for both my bed and my running boards.  There are a MILLION Chinese led lights out there, but many of them seem to have limited life, arent actually waterproof etc.
Does anyone have a brand that they have used that has worked well?  I will tentatively say the budget is ~$75 for the lighting (should need ~24 ft of it.)
I bought these for my running boards:
https://www.amazon.com/gp/aw/d/B073ZGNDTC?psc=1&ref=yo_pop_mb_pd_title
I spent hours looking and that's what I decided to get. No issues after 5000 miles and crazy downpours on the highway and plowing through 1ft of water.
What I liked about these was not only were they the typical waterproof LEDs that everyone sells but they were also encased in a tube for extra protection. They also come with genuine 3M VHB adhesive tape which is extremely sticky as long as you prep the surface. The color temperature is around 6000k so they are pure white and match the LED headlights and interior lights, unlike some that are either too yellow or start to get on the blueish side.
They are also used for the bed lighting but for the bed I went with the OEM kit: https://www.ebay.com/itm/2016-2018-Sierra-Silverado-Genuine-GM-Led-Bed-Lighting-Kit-23295943/302225809148?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
I know the OEM kit is over the budget you want but I thought it was worth it. It is plug and play to the wiring harness under the spare tire and mounts to the bed where there are predrilled holes for it. The OEM kit is mounted towards the rear of the bed, so it doesn't light much of the front of the bed, but I have an electric tonneau cover that has an LED which covers the front. Just for the heck of it I purchased a second OEM kit and spliced it into the rear set for full coverage.
Thanks, I was definitely looking for a brighter option in the bed than the OEM lighting kit, as I heard it was sub-par.
Thanks for the link.  Ideally I would like something without a switch because I am just going to splice into my AMP steps anyway.  I will give these a look.
You don't use the switch that comes with those lights. I have AMP powersteps as well. You just cut the switch off and splice directly into the wires where the original LEDs for the steps where.
Can you post more pics of the bed lights? Maybe one showing them from a distance.
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
