3500HD Suspension for a 2500HD
I want to add the overload springs from a CC/SB 3500HD to a 2500HD.  I need the brackets, pads, bolts, springs, u-bolts, etc.  I am wanting to go the genuine gm route instead of just putting on airbags, helper springs, etc.  I like the truck to look as factory as it can and I also don't want to have mess with the air in the airbags.  I put some on another truck and they are helpful but a pain when you forget to air them down/up.  I have found a few of the parts but not all of them.  My truck is a 2013 CC/SB.
On 6/30/2018 at 11:00 PM, davester said:
Or find a wrecked one in a junkyard. Cheaper and you can get all the parts you need in one shot.
I'm having trouble finding a wrecked one near me.  The best I have been able to do was see someones in a parking lot to look at some of the parts.  I figured the new parts would be the best option for finding them, not so much for the value.
  • 3 weeks later...
I have a pair of these heavy duty springs sitting in my garage. The previous owner of my 04 Silverado 2500hd used them to turn the truck into a 3500. We don't haul that heavy so they didn't work for us.
We are talking about the thick overload leaf, right?
 On the older truck like the 04 they had more leafs in the pack for a one ton single wheel.  We have a 09 single wheel 3500 here in the yard that has them and its gvw was 9,900 vs a 9,200 for a 2500HD, just no top overload leafs. Some of the one tons with a single wheel had the top overloads but I don't know if they are the same as the ones on the new frame or not.  We had an 05 3500 single wheel that had the top overload leafs but it was scrapped out when one of the farm hands rolled it so I wasn't able to check it.
I am looking for the spring pack at about the 1:30 mark on the video.  I basically found all the parts from GM except the bolts that hold the bump brackets to the frame.
11589273 are the bolts for the rear stops, 11516078 is the nuts, 11589278 are the bolts for the front stops, same nut as the front.  GM doesn't sell the overloads on their own, only part of the entire spring pack which is 23401104.
Thank you for the bolt and nut part numbers.  I had everything else but them.  I figured that they wouldn't sell just the upper overloads.
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
