Some time back I used load levelers in the rear of my 2016 Denali 1500 for use when I pulled my trailer.  I was shocked that the ride got worse only to find that I had to make new rods for the suspension position sensors. The shocks thought the rear was under load at all time firming up the dampening.  After getting that sorted the truck went back to riding like stock but still pretty firm so I purchased a set of 18's to try.  Though there were some small differences it was not worth talking about.
I even tried reaching out to DSC Sport to purchase a new controller which I have used on my P-Cars, Vettes, GTR...... but they are working through the sports cars and not interested in trucks.  Now my thoughts have turned to modifying the leafs or removing the Magna Ride shocks from the rear and installing a traditional shock.
I drive the truck 40-50K / year all highway and only 3-5K with a trailer, rarely putting over a few hundred pounds in the bed.  Hopefully the 2020 trucks have this worked out with the new ride option menu but until then I am keeping mine.
Anyone hear have any suggestions?
  • Replies 34
Top Posters In This Topic
No advice but I feel your pain. I hated the ride when I drove a denali with mag ride.
you can feel every little thing on the road. Great on a sports car, but terrible on a big boaty luxury truck
Very interesting and timely comment.  I was in contact with my favorite GM salesman yesterday and expressed interest in refreshing my '15 SLE  before the '18's are all gone.  We concluded that a Denali would be the model that would have enough improvements over my current truck and the incentives would keep the price reasonable.  I have also become hooked on the RV lifestyle and may eventually trade my TT for a smallish  1/2 ton towable 5th wheel.   Is the Denali a poor choice for towing?  I want the comfort features as my plans include a lot of touring through Canada and the US.
With that specific use in mind a Denali probably wouldn't be my first choice.  The Magnetic Ride shocks do complicate things, but the big issue is the NHT package isn't available.  Specifically for RV use, especially if there's a chance of a 5th wheel in the future, the extra payload of the NHT can really be beneficial.  A standard length box is also much better for that, and while they do exist on Denalis, it might be hard to find one.
As for the OP's issue, I do think it's possible to remove the magnetic shocks, I think I've seen threads where people do that and use something to fool the computer but I haven't paid much attention.  A good set of aftermarket shocks can provide a really good ride, there are a lot of choices out there.  I'd also suggest having Deaver make you a custom spring pack for the rear, giving them your goals so they can make a set of leaf packs that will give you the ride you want.
I would add with a 5th wheel I would probably shoot for a 2500.  Though my 6.2L pulls 24'L x 8.5'W x 6.5'T enclosed trailer that loaded is 8,000# trailer, the 2500 Duramax pulls it like mine pulls a 2000# trailer.
Removing I am sure is not easy, I figured I would start with resistors but worry about dynamic feedback that will throw a light.  I like the spring idea but since I have bags already I wonder if that would help much.  I am going to give Deaver a ring and see what they have to say, I really like the idea and it appears they make a top notch product, thank you very much for the heads up!
I'm sorry, I missed the fact you have airbags.  How much air do you normally run in them?  If you have much air in them when you aren't hauling much they will firm up the ride, there may be some improvement to be had there.
We need more info? Tire brand & size, tire pressure (tires tires tires!!! will completely change how a vehicle rides )
factory on mine was... (horrible tires)
Goodyear's
Eagle LS2
P 275 /55 R20
I run factory chrome 20" wheels with Michelins 275/55-R20 (factory size) @ 35psi rides smooth as glass even loaded. .
If you are running 22" wheels on Manga ride I have nothing to say.
even though you lengthened the rod for the Magneride, you should probably have a "trim height relearn" done anyway.
the 22's with 45 profile tires ride like bricks, change those
I wonder if it is the airbags as well?  My 2015 Denali rides great compared to a friend of mine's 2014 Silverado, which the back end is a little harsher on bumps compared to mine.  I have 20's instead of 22's as well.  I tow a 21' boat with mine and haven't had any issues with it, actually feel as though the Magnaride controls the tow better than stock shocks.
Great point, I have tried pressures from 10 PSI up to 50 PSI.  One thought was that the dynamic velocities were to high due to the reduced spring rate and the shock was compensating with a stiffer high speed compression or rebound.
Goodyear's
Eagle LS2
P 275 /55 R20
I warehoused the factory 20" wheels with the LS2's in 275's, installed an OEM set of 18's with OEM Duelers but there was not much of a change.  As for tire pressures I have tried from 31-38 PSIG in the rears but did not notice a large difference. I put the LTX II's on my last 14' All Terrain and was very happy with them also.
I did not know this is possible I am going to start researching now, being able to do a relearn would be fantastic!  My dealer has said nothing about it, and to my knowledge there was no way to do this.  Thank you so much for posting!
There definitely needs to be some clarifications here.  The ride is still, particularly in the rear but the handling is leaps and bounds better than any other truck I have owned or driven.  The shocks are one of the main reasons I bought the truck.  Really my frustration is that I can make all the changes to my other cars to get the ride where I want it but GM omitted this option from the trucks and the aftermarket companies aren't interested in the market.
Again thank everyone for your help and comments!  As of now I am hoping the Trim Height Relearn will make things better!
I am running air bags in my 18 Denali. I found a set from Air Lift ( Ride Control bags) (2,000lb bags) that mounts to the outside of the frame and the top of the leaf spring which does not effect your magnetic ride arm. I pull a 7000 + lb boat all over the place.. Big difference with helping with the sagging in the rear without affecting the ride quality. I also have a 2” leveling kit in the front.....   My old bags from them mounted to the axle and frame which would not work with the Denali, obviously cause of the shocks...
Edited by JohnnyH
would you mind posing what part number you used?
thanks
Yes, sorry... That would have been a good thing to do.. Model # 59565 AIRLIFT.
Edited by JohnnyH
Here’s a better pic so you can see how they mount.
I have saw those but never really paid them much attention. They don't stiffen your ride when unloaded? Running 7 psi in the rear unloaded like regular bags?
Sent via Morse code
    Chris80s
    Chris80s
  • Who's Online   4 Members, 0 Anonymous, 906 Guests (See full list)
    • Still $3.01 with even more places at this price
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
