No they do not stiffen the ride. I run about 5 psi in them. Not as stiff as a 5,000lb load lifter bag. I had a 2017 gmc all terrain with those and yes the 5,000 bags def stiffened up the ride on that truck, I ran those at 7-10 psi because they replaced your pump stop. These bags are a lot softer so they give more at low PSI and even at 30-40 pnds Which is what I run them at with my boat it’s still a soft ride.    I would definitely recommend these for people with The magnetic ride control. I’m happy with them!
  • Replies 34
Top Posters In This Topic
Put this setup on my DMAX
On 7/22/2018 at 5:02 AM, JohnnyH said:
Yes, sorry... That would have been a good thing to do.. Model # 59209 AIRLIFT
those are listed for a 2 wheel drive lowered truck... but they appear to be working on your 4 wd?
SORRRRRY! Wrong ones, I screen shot the wrong ones!...  They look the same.. MODEL # 59565
I was excited to see this post.  I have been looking for air bags for my Denali and knew that the magneride was going to be an obstacle.  I went straight to the Air Lift website to do a little more research and their website says that their air bags are not compatible with magnaride.  I searched for this part number and it also states that it doesn't fit vehicle equipped with magneride.
Did you have to make any modifications to make this kit work?
Correct.... But it works. I have had it on for about 5 weeks now and have about 400-600 miles pulling my boat which ball park is 7000-7800 lbs.  here’s some more pics I just took. If you look the bag goes on top of the spring so it keeps your sensor air right where it needs to be since you are not lifting t from the axle to the frame. The sensor is attached to the bottom of the leak spring so you are lifting it above it’s mounting spot ...  No modifications at all, direct bolt on!!
Edited by JohnnyH
Thanks JohhnyH
Your welcome Dave.... No worries man, it works!! I wore myself out looking all over the internet for a solution for the weight I had to pull...Sucked haha.
On 7/21/2018 at 6:18 AM, JohnnyH said:
I am running air bags in my 18 Denali. I found a set from Air Lift ( Ride Control bags) (2,000lb bags) that mounts to the outside of the frame and the top of the leaf spring which does not effect your magnetic ride arm. I pull a 7000 + lb boat all over the place.. Big difference with helping with the sagging in the rear without affecting the ride quality. I also have a 2” leveling kit in the front.....   My old bags from them mounted to the axle and frame which would not work with the Denali, obviously cause of the shocks...
I am using my 18 to pull a fifth wheel and was recommended the Sumo coils to level out the sag. I'm thinking for like money the air bags might be the better choice. what is the tongue weight of your boat? do you have the compressor on board?
I haven’t scaled my tongue of the trailer, safe estimate using the 10% I’d say about 580-700lbs depending on how much fuel Is in the boat. 100 gallon, gear yad yada.  I have not added the compressor yet, but will be now that I know the bags work!...
Edited by JohnnyH
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
    • That's interesting.   There was a factory wire-hole in the back, top of the rear cab, which had a wire for the third brakelight assembly running through it, as well as several holes (10 of them I believe) for all of the studs coming off of the 3rd brakelight assembly itself.   I sealed all of those holes with RTV/silicone as well.   I found it kind of odd, that none of those holes, were sealed with any kind of sealant by the factory - if there was any there, it wasn't very much.   That said, I've been out in heavy rain and have ran the truck through high-pressure car-washes a few times now and she has been 100% water-tight to this point.   I feel very confident in the repair, we'll see how it holds up.
    • I bought a used 2022 2500hd with 6.6L in February. In March took a 2200 mile trip towing our 6500 lb trailer. Changed the oil day before leaving and when we were arriving at our 1st destination, low oil light came on (roughly 1000 miles) it was 2 qts low. Now it towed like a dream, no issue there, and we did go through the mountains of TN, but still, 2 qts! Luckily I did purchase an extended warranty. Brought it to the dealership in April, oil change and consumption test. Brought it back last week, 1300 miles, no towing, and no oil showing on the dipstick. GM is reccomending a new engine (cheaper than them rebuilding), we'll see if the warranty company comes through.
    • T3's and Ibuprofen. I do have a cryotherapy unit (ice machine) and a lift chair that will allow me to raise my legs above my heart.  There are topicals that I can use once the wound is fully healed.
