Engine light and too much air?
Took our 2017 Silverado, with 2,200 miles on it, on the first long trip across the state. Everything went without a hitch until day 2 when I was driving on the highway and the engine light came on, engine revved up, and speed dropped to 35 and wouldn’t go any faster. It ran normal, with the engine light lit after I restarted it. Limped it back to the inlaws with no further problems and the following morning the engine light shut off when I topped off the gas tank. Got an OnStar email informing me of an issue with the engine/transmission and to take it in for service within 7 days.
Just left the dealership and they said they couldn’t find any trouble codes or problems... In regard to some transmission jittering I’ve noticed on slow to normal acceleration, they said they couldn’t replicate it and suggested I remove my Airaid intake tube because the engine may be getting too much air?!
On the bigger problem, my only thought is that it might have something to do with it being the first time I’ve ever ran it down to 1/8th tank of gas. Maybe a contaminant, fuel filter, or sensor glitch...
There should have been a code(s) stored in history/memory.  Check for vacuum leaks, loose Airaid and such.
That’s what I thought too about the code(s). Good idea, I’ll check all the connections.
Check your filter, if it has too much oil on it, it will mess up the MAF sensor and throw codes and light up the CEL. The oil is sucked into the engine and coats the MAF sensor along the way.
Too much air sounds like they don't know what happened or don't want to spend time investigating it.  Their MO is to get the truck out if the issue isn't obvious or repeatable, they don't make any money on troubleshooting intermittent issues.  I bet they just want you to take out your Airaid so you feel like it was you that caused it and don't ask more questions.  If the truck went into limp mode, there had to be a code, which might have been as simple as a glitch from the MAF sensor or something.
I’m still using the stock paper filter, so good there. Once that’s used up I’ll go with the Airaid dry filter.
    B07
    B07
  • Who's Online   2 Members, 0 Anonymous, 539 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
