GM MVAC specifically Dryer info needed.
Recently I got my A/C compressor replaced, no dryer was replaced? red flag!!! I noticed on the warranty paper work that the dryer was not listed, when I asked the service director & dealers team leader in the shop, about why no dryer was installed, I was told is b/c its not needed. I was completely baffled! Keep in mind I was a ASE and Mercedes Benz master certified tech... with a 609 cert. If that means to anyone b/c they kept throwing in my face we have WORLD CLASS MASTER TECHS... just laughed b/c as a Master Tech my self I was like its kind of funny but whateve's.
looking for GM technical help here about why a dryer is NOT replaced when the system is open especially a compressor replacement. not 100% sure but it appears that the dryer is sold separately from the condenser unless it requires condenser replacement
any GM techs willing to provide some info..
so I had the grille off, getting access to the bottom of the condenser requires one to R&R the condenser.
Thanks
Recover, replace compressor, evacuate and recharge per GM service info. Just sayin'. I get your concern though. Years ago they offered an inline filter to add in after a replacement, haven't seen them in a long time. The only real concern would be debris and I don't know why your compressor was replaced. The receiver/dryer is serviceable but does require condenser removal.
The dryer should have been replaced period. I’m sure you know why and all the reasons. Doesn’t matter if it’s automotive HVAC, residential or even commercial HVAC, if you open the system up you replace the dryer. But like tbarn stated, you do as instructed or what GM service info tells you to replace and flag only. I don’t blame the tech but I would bitch at GM customer service care.
  • txab changed the title to GM MVAC specifically Dryer info needed.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
