I just changed the cabin air filter in my 2016 Suburban.  Before the filter change, there was the normal noise when the A/C system was on.  Now, there is a HORRIBLE humming sound coming from the vehicle.  It is so loud, that you can hear it outside of the vehicle.  I popped the hood and you can hear it near the passenger side firewall, sounds like a sucking sound.  I read on here where debris can fall into the system when you change the filter, so I checked that.  Nothing.  The noise began instantly after changing the cabin air filter.  What have I done to my Suburban?  It makes it miserable to drive now.
You dropped an acorn or some other crap into the blower motor. You can't believe how often this happens.
I tried my best to check that, even shoved a ShopVac hose down the opening and no luck, still noisy as ever.
Okay.  I'll try that in the morning.  At work right now.  Thank you!
Ok, gave it a shot again this morning.  Removed the filter and turned the system on, hum is even louder with the filter removed.  Filter reinserted and the noise is still present.  Tried everything I could try to remove any debris that may have fallen in there and nothing comes out and cannot see anything in there.  Noise is driving me insane.  I actually want to set this thing on fire now.  J/K of course, but almost to that point.
  • 3 weeks later...
UGH. I took it to the dealership the other day and they claim to have vacuumed it out and the noise is still present.  How do I fix this?  Please help me before I go insane.
I had the exact same problem.  Does the sound change when you use different doors?  Floor, defrost etc?  Did you use a Fram filter?  I did, same problem your'e having.  I pulled the filter 6 times, no kidding.  The final time I made sure all air and blower was off and the air flow on the filter was correct.  When I put it back in I went through all the doors with the blower on low and it quit.  I don't know why.  It quit though.  Sorry about the problem.
  • 2 years later...
Hi Ghettosled, I’m literally in the same boat. 2016 suburban changed the air filter, which had a mouse nest, and now I have the worst sound coming from what seems like the compressor. Did you find a solution?
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
