Hello everyone, im creating this post because there was little information about this lift kit when i was looking around. I have a 2018 Chevy Silverado 1500 Z71 and i wanted to lift it , but i didnt want to go that high. I eneded up deciding to go with the Rough Country 3.5 in Knuckle Lift kit with the N2.0 Front Shocks SKU :12132. The kit is around 600$ and its a 5-6 hour installation time. I know some guys dont like RC , and the other chevy kits didnt have many happy customers. This kit was relatively new and it came with knuckles which is suppose to fix the suspension angles that a level kit would ruin , and it did. I had a 2.5 Moto Fab level kit and the truck ran really hard and i didnt like the ball joint angles. Well I can say that im happy i went with this kit . The truck rides really good and looks great. I was able to fit Nitto RidgeGrapples 33x12.50 and XD series Buck 25 20x10 wheels. It rubs a little at full crank at the lower rear plastic trim. I’ll post pictures so you guys can see. If anyone has any questions feel free to ask i’ll answer them as soon as i can , i hope this post helps anyone decide what route to go with when deciding a lift kit.
Edited by Irving
Typo
Angles still aren't right, I just had this kit ripped out of my truck and swapped out for a 5", lift is trash and will cause you nothing but issues. All good if you plan on keeping the truck 2 years or less.
What issues did you have?
angles are too high, rough country is notorious for bad angles on their lifts that knuckle doesnt look taller either its just modified to save balljoints from the terrible angles... good lord RC what next..
Edited by SarahsGMC
So i still might run into problems? Lol
Ball joints, steering issues, ****ed cv boots, ****ed with stabilitrac and steering assist. all before 40000 kms... Truck rode like a ****ing tank, rubbed everywhere. Zi much better now, ride a like factory and angles are corrected
4 hours ago, Dustin Cornish said:
Your also running offset wheels so that eont help either lol Top is before, bottom is after
So you went with a RC 5 inch lift after you were running into problems with the 3.5? The truck looks sexy as F**K by the way
Edited by Irving
the CVs will have premature wear, your balljoints upper lower and outer tie rod ends look to be in better placement so you might be ok there, just depends on your driving style.
I cant tell you how many ball joints and CV shafts ive destroyed and I have good angles on my  7" haha
Damn haha , well i already bit the bullet. I’ll see how long it holds. If its too much then im going to have to upgrade to a better kit like BDS or something that can correct cv angles as well as the ball joints. Thank you for your time I appreciate it
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 1,921 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
