my gps lost signal about 3 days ago in Alabama and hasn't recovered. I'm in Texas now and it still has me located in Alabama where I noticed signal lost
2015 Suburban LTZ w/42,000 purchased new in Dec 2015 (~2.5 years in service)
In May 2018, my Sharkin antenna failed (antenna was completely filled with water).  I'd bet this is also your issue (GPS showed me in middle-of-nowhere, and normally green OnStar Light glowed red).
It is a well-know issue for which GM offers a customer satisfaction program to repair at no cost.  Though, despite my year and model of vehicle being included in program, GM insisted (based on VIN) that my vehicle is not covered, and this was an out-of-pocket repair for which GM offered zero assistance.
Dealer quote $600 to repair but finally agreed to do repair "at dealer cost" for $400.
When antenna failed, prior to dealership replacing, water flowed from gasket between antenna housing and roof when pushing slightly on antenna cover.  Despite obvious water issue (I kept antenna, and it is still filled with water over 2 months later), GM refused to acknowledge that is it related to GM customer satisfaction campaign issue.  Maybe you are lucky, and your VIN will be included.
I would recommend pushing slightly on antenna cover as I did while recording video with your phone.  Maybe if your VIN is also not included, GM will have harder time saying it is not same water intrusion issue.
Good luck.
  • 2 months later...
I realize this is an oder post, my shark fin had failed.
Not hard to replace, just make sure you use the correct adhesive (NOT Silicone) to seal the mounting surface.
Disclaimer - I'm not an "auto body repair', nor do I play one on TV.
When I replaced my shark fin antenna, my dealer service advisor printed out a copy of the replacement procedure for that,  and it called for 3M Flexiclear Body Seam Sealer 08504 (in my case...available though Grainger).
"Excellent for Exterior Automotive Sealing
3M™ Flexiclear™ Body Seam Sealer is a caulkable exterior sealer which adheres to surfaces such as primed and painted metal, glass and aluminum. Our sealer dries clear and resists yellowing for a clean, low profile appearance. It uses a standard "caulk" style dispensing system. It's fast drying and ready for painting in approximately 45 minutes."
Most Silicone's are generic, and fail over time (for several reasons)
Personally, I have too much invested in my ride to go the cheap route, especially for a roof mounted device that could potentially leak.
I used the recommended 3M Seam Sealer and have had NO issues, my truck goes through a car wash weekly (sometimes more).
  • 3 years later...
Our 2015 Tahoe GPS just started showing the wrong position. It has us about 40 miles off, and, in the upper right of the screen are the letters "GPS" with a red X through them. .  Also, the vehicle does not recognize my iPhone 6 anymore. I've read where there might be issues since 3G has been replaced by 5G but no one else I've talked to is having issues with theirs??? Also, GM has a GPS update for about $150 but I can't find out if it covers that issue. Does anyone have helpful suggestions?
  • 1 month later...
The GPS update is probably a new version of the map data.  I did that a couple of years ago when they had it on sale.
Since GPS units talk directly to the satellites, changes in cellular to 5G are irrelevant.  This may be different on your cellphone.
    Afennell19
    Afennell19
  • Who's Online   1 Member, 0 Anonymous, 928 Guests (See full list)
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
