19 minutes ago, lapoolboy said:
Everything worth doing is illegal in California.
 That’s not true you can lane split on a bike unlike the rest of the US. But yes that is about the only exception...
And even then, they are still splitting lanes at 80MPH+.  The original concept was to split lanes during traffic jams.  CHP and other LEOs need to enforce it.
When I had my canopy installed I had them run a hot wire to the light and to a triple 12V plug outlet by the tailgate.  This way I have access to lights and power when camping without entering the cab.  My thought here is you could run an independent wire hooked up to a couple of lights in the box with a discrete spring loaded push button mounted on your dash or console.
I am interested in a simple work around too because for me it is important to be able to utilize my cargo lights for me it's not illegal because I have a cap on my truck and they're technically interior lights , I have use them extensively on the other brand trucks in order to monitor my hunting dogs
Now that I have done the orl switch mod I have a extra switch I have already mounted in my cab. I’m thinking about having it control a separate 12v hot wire connected to the factory bed rail light harness under the spare tire.  This would allow them to still function as they are stock. But then if I want to flip the switch and say I’m in gear it should light the bed rail lights up. My only fear is back feeding it and some how blowing up the bcm or something. Any thoughts?
Is there any possible way to have the cargo lights up while putting it in reverse? The tail light comes on but not the bright white light on top as on the cargo. But breaking taillights lit up does works. I would love to see my mirror lighted up as well while going backwards. Kinda lame that we don't have a functions to be a setting on our stereo system to be able to do what kind of lighting system programs on our trucks.
Yes, there are a few threads out there that discuss this, all in the MODS section.  You can use a wire, in Reverse - cargo & reverse lights come on, and turn on the cargo lights - they all come on too.  Use a diode, depending on which direction the diode is set, dictates which mode triggers the lights.
The diode mod is a great mod! It's the most practical mod I've seen, the diodes cost a few cents, and it takes about a min in total to do! Now I use my key fob to turn my cargo/reverse lights to see in the bed of my truck, and for extra light when entering/exiting my house.
And as always... Enjoy your ride!
So I finally got some time and got mine to function exactly the way I wanted to.....
i have an additional switch in my cab that allows me to turn on just my bed lights with the truck in the on position in any gear there for this will not blind the car behind me as it’s only the bed lights. Of course I have added a set of 4 rock lights to the stock ones so I have way more light in the bed.
spent about 20-30 bucks on this.  I placed a relay in the rear and placed a road master diode in the rear as well.  The diode I got allows for 2 inputs and 1 output.  So I just cut the supply wire to the bed lights in two and placed the part going to the lights in the output put the other end in one of the inputs the other input comes from my relay. What this allows is for the bcm to not be back-fed.
i got the 12v power and ground from the trailer plug wiring.  So in theory you could use this to add a switch in the bed if you really wanted instead of having to run a wire up to the cab.
Do you remember which wires for the trailer plug? i plan on doing this with a relay to put a switch in the bed of the truck.
Can you also mount a forward camera facing into the bed or behind? Forward cameras work while driving, right?
Thanks! I honestly forgot bc I tapped the wires I had used when I did the remote drop tailgate on mine.
I’m interested in the remote tailgate drop. Can you give me any more info on it?
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   1 Member, 0 Anonymous, 496 Guests (See full list)
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
