Tri-Mode Steps for '17 Denali
I removed the Tri-Mode steps that came with my 2017 Denali Ultimate.  I've not seen much online in terms of being able to put them on another GM/Chevy.  Any ideas?
Also, any idea what these cost NEW from a dealer?  I'd like to sell mine in the Houston area.
I know there have been a few threads with some people actually advertising the factory trimode steps for sale. I am think they were around 1000 bones used? I think a set new from GM Parts would be around 3 times that. Problem with getting them to work correctly is in the BCM programming from what I understand. Their was a fella that had a damaged set that he replaced by buying a used set online on this forum, so that might be your TYPE of customer if you can find someone that needs a replacement?  From what I remember a repair shop had damaged his when they put the truck on a lift and the lift arms damaged the boards.
I am sure they are pretty expensive when bought as a kit from GM.  When you price yours consider it is a complete kit, to include the all the mounting brackets/hardware, wiring and control module.  The BCM programing can be done at any GM dealership and shouldn't cost to much.
If I were you I would definitely price them quite a bit lower then a set of new Amp powered steps.
