2018 2500 hd. The very thin plastic lens on my gauge cluster is cracked. GM says I have to buy an entire instrument cluster. Does anyone know where to get just the clear lens?
Thanks
I think this ebay part is the part that the lens attaches to. I just need the clear lens. I haven't removed the cluster yet to see if it's 2 parts. Maybe someone knows? Would be great if the lens was included with this part. Email to seller sent. Thanks for the link.
Edited by Jrs 94
Looks like the LENS and Bezel are all one piece.  On my '91 Chevy K1500 the IP (Instrument Panel) LENS was a separate part than fastened onto the bezel with screws.
https://www.ebay.com/itm/NEW-OEM-88-89-90-91-GM-1500-TRUCK-SPEEDOMETER-CLUSTER-CLEAR-PLASTIC-LENS-ONLY/221057766334?epid=1289425428&hash=item337811d3be:g:HigAAMXQsoNRg5wQ:sc:USPSPriority!43952!US!-1:rk:3:pf:0
The LENS in the link above is for standard the non-tach cluster in '91.  Another LENS part number is required for the '91 optional Tach cluster.
Agreed the 96 1500 I'm replacing is 2 parts as well. It's crazy how thin this part is. Barely hit it. I have an email in to the seller to verify that the part fits. I hope so, I've only had the 2500 for 3 weeks <2000miles. *&%$ happens.
Hope it is the correct part.  Probably heard this a million times - Take your time replacing this piece.  Good luck with it!
Just finished putting it in. Perfect match. Very easy to do. Took about 20 minutes taking my time.
Thanks for the eBay search, I had never used it before.
  • 8 months later...
Just wondering how much was the part? Where did u get it from I recently did a dash swap and broke the lens taking my airbag out with a flat head (didn’t pop the airbag) took airbag out
to take the steering wheel out to remove the dash.
any info? Wanna fix it before I sell it
I tried to hit them up but no lucky, idk mine is 2014 so u have to replace the lens and cluster bezel but the newer trucks have where u can replace just the Len...,  idk about spending 75$ on that
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
