I have read a lot about adding the factory rear view cam to my 2016. I have ordered the camera and handle assembly and it should be here next week hopefully.
I was going to order the OBD Genie programming device that turns on the rear cam but started thinking that if I do that, and the dealer ever has to reflash my truck I may have to go back and use the obd genie again. No big deal unless something happens and the genie dies over time etc.
My local dealer said they will add the programming for $175. They said $100 for something from Chevrolet’s side and then $75 labor. The Genie is $199 and I dont have to go to the dealer and deal with all that.
Anyone one have any advice or opinions on either option?????
Edited by t76turbo
Spelling
What is the genie? I just recently added factory backup cam in my 16.   Are you prewired under the truck and at the hmi?
I found a few people talking about the genie. It is a small obd2 device that programs the radio to accept the rear camera. Works just like factory. I don’t know how technically it works differently than what the dealer would do. But the threads I read about it say it works perfect. Just saves trip to dealer.
https://www.obdgenie.com/collections/gm-genies/products/gm-rear-view-camera-programmer-g-rvc
to be honest I am not sure about the pre wire part. I figured my 2016 Lt trim truck should have whatever it needs. If not I am screwed I guess.
Check the wiring at the tail light distributionblock and the wiring in the grey plug at the hmi
Might try to rephrase the question....
I have been thinking of getting a 2.5 HMI to get Apple Carplay.  The seller said they can program in the Rear View cam which is the same thing the OBDgenie does I guess.
So to rephrase my original question, what difference could I experience between getting the dealer to program which I assume changes the configuration with Chevy as well or getting the HMI programmed by some other means?
Could you tell me what wires I will be looking for specifically?
2015 Silverado LT Midnight Edition
4.5” CST suspension lift
White wite with blue stripe, grey wire with yellow stripe. Has to be in the rear light block the the grey plug attatched to the hmi
81995af5ccff72b67e567e54c5028465.jpg I would say I’m good to go! It appears they are in the back junction box as well.
Check the rear. Its the 3rd plug from the left by the spare tire
I checked and they appear to be there as well. So it should just be a plug and play, I’m upgrading to apple car play and it is apparently already pre programmed for reverse cam
Make sure the new hmi is programmed for it. Its also a good idea to have the radio module updated because if its not then the projection icon wont work which makes android auto and CarPlay work. Ihad to do that
Hello everyone, a new member, created an account just for this topic! I am curious about the OBD genie as well, I have done a lot of research and wish to add a backup camera through the tailgate handle to my 2015 Chevrolet Silverado 1500 LT. So the way I figure it, I can buy a tailgate camera through someone's website, or from the dealer, and have the dealer flash the IO4 that I have with the new programming and pay about the same price as buying a OBD genie and camera from a website? Does that seem about right?
  • 4 years later...
Hey 👋🏼. I’m looking to install a backup camera and would love to borrow an Obd genie instead of buying one new. Anyone have one and willing to lend it? Thanks
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
