2003 5.3 tripping P0135 P0141 P0161 P0171 all at the same time
I am trying to get my 2003 Suburban back on the road from sitting. I had a rodent chew a bunch of interior radio wires while it was sitting. I tore everything out and fixed every single wire I could find. Initially it was only giving me a P0171 and an oil pressure sensor code. Since the dash was displaying 80 lbs of oil pressure before starting I replaced the sensor.
Now today after like the 4th time driving the car the CEL popped on at the same time my radio started displaying that my parking brake bypass was no longer working. Based on what I found online it is almost always a blown fuse that triggers multiple O2 heater core faults simultaneously. Everything I read online tells me these trucks have O2 sensor fuses in the engine fuse block but mine has none. I pulled every single fuse from the block both in the engine compartment and in the dash and they are all good.
I replaced the rear driver O2 sensor from the first time I was getting the P0171 code so I know at least that sensor was is good. Any ideas? I would think if a wire melted somewhere or shorted out that it would have blown a fuse somewhere. Any help would be appreciated.
7 minutes ago, sefiroxx said:
On my 04 Sierra, one fuse - O2B
On mine I don't see anything that says O2 unless I am blind which is possible. This is the engine bay
4 hours ago, sefiroxx said:
Look at the Legend at bottom. You'll see O2A and O2B marked as 3 and 4. Find 3 and 4 on the map.
Thanks I didn't see that. Both fuses are good and haven't blown. I'm just confused on how I could trip 3 O2 heater core codes simultaneously and have no issues with the fuse. If a wire had burned or shorted it should have popped the fuse right? The car has been sitting for a long time. Could it be an issue with the battery? The car starts fine but the only other thing I can think of is the PCM.
Many kinds of shorts, many kinds of symptoms - only one of which is blowing the fuse. Other symptoms include slow drain, incorrect voltage signals, interfere with neighboring circuits . . .
10 hours ago, silveradosid said:
all the sensors use one common ground check that ground to see if it is corroded
We live in California so not a lot of issues with corrosion. I checked all the grounds and cleaned.There weren't any issues with any of them. I put the predator on it to do data logging and with the truck idling the voltage between the 3 O2 sensors I didn't replace varied between .07 and .88 moving up and down. The sensor I just replaced on Bank 1 Sensor 2 was sitting at .05-.06 and wasn't moving. Could the new sensor be the issue or is it possible that the issue is with the PCM on that line? I checked every harness in the car top and bottom that I could see running and I didn't see any tears, frays, or anything. All I found was a 2 prong connector not hooked up to anything coming off the passenger side O2 harness, but I have heard others say they have a phantom plug too. I checked the inside cab grounds as best I could. I had the dash off doing wiring repairs and don't remember seeing anything with the ground.
Any thoughts then? The wires look good and it is triggering multiple O2 codes at once. I don't know if one bad sensor could cause the issue with the others. My plan is to put the old rear sensor back in and look to see if the voltage changes or remains fixed at .05-.06. If it does then I'll switch passenger side and driver's side to see if the voltage issue remains or moves with the sensor. Originally I only had one code popping up. After replacing the rear O2 I drove it for quite a while around the neighborhood and had no codes. Then boom codes and no voltage randomly but the fuses are good.
Sensors in front of the cat should cycle positive to negative - reflecting what the computer is doing to adjust injector opening time (more fuel/less fuel) Sensors behind will usually be stable and indicative of cat efficiency (gradual change of signal indicating slow consumption of cat metals).
If the front sensor are cycling, good but if not around 0 then they may be corroded or the engine needs work.
    • What meaningful corrections were done to fix the "machining errors?"   I bet nothing, because the 6.2 is soon to be obsolete. Why would GM implement any fix let alone an "expensive one?"   Until someone can provide any convincing information that GM did ANYTHING to correct the engines - the 6.2 is no for me.    Which means keeping the 2016 Denali longer until the next generation (6.6?) proves itself.
    • If my father took a Sunday off. We did the Sunday drive. Usually stopping at a Geno’s for dinner that we eat in the car. Six of us with my little sister up front. It was always a Buick growing up. In New Jersey you couldn’t get lost. Not like Texas.
    • Hoooooooly smokes, batman!
    • I suppose I am Atlas. It can always be worse, eh?   I had a friend once that rolled one payment into another until he was paying the price of Benz for a 10 year old back marker. Wouldn't be often you start a new payment the month following your old one.
    • I still enjoy the drive   Some people fish when they retire; some golf. I drive. We've lived in the same general area now for twenty eight years and I'm still finding at least monthly some sweet quite little road to explore. When I tell the Mrs. I'm heading out for coffee she knows that could be a five hour event. Often she even goes along.    I like finding new rural routes used mainly by the locals that start nowhere in particular and end the same way. Many in the area of that type are narrow paved and twisty, hilly and run through field and timber. Often along creeks or wetlands. Unfarmable areas of great natural beauty.    After years of this type of exploration they start to fit together. One ending a mile or so from another and you start threading together a new path from a unfamiliar place to a new adventure. Sometimes to a little town of under five hundred that used to be something before the Interstate or some railroad or US highway bled the life out of it that has a small dinner with the greatest slice of pie you've eaten since grandma made her last. A little village museum or library or even a town square park with grand old oak, walnut and Osage orange trees to sit under while you sip you gas station coffee and chat up some locals.    Often they are full of stories about the main streets more interesting buildings and the who's who of the area. Sometimes some hidden attraction or unseen history. Our area is full of old coal mines.     A younger self used to do this going cross country by motorcycle. Only a general area as a destination with no time to get there and no time to be back. Sitting at days end in a 10 unit off the main highway motel under a Sycamore tree yacking with the owner or his one semipermanent guest while I adjusted valves or the chain. Always a wave and a shout "Hey there stranger"!  It's how I came by my love of old Brit iron. There is no such things as a ten minute gas stop when your on a Enfield or a vintage Triumph. Same being true of old cars.    If you take the time to really look I've found everywhere is someplace interesting. Illinois or West Virginia. Different and yet the same.    People are in a more relaxed mood and will talk about anything and everything and if they like you there may be a cupp'a or a lemonade and a sandwich in it. 😉
