Diff lock
An open rear axle spins both tires in a straight line if you get the weight distribution on it right.  Doesn't happen more or less on anything where you don't have independent rear suspension.  A little drag one way or another and voila, both tires.  Big difference between that and something that actually locks the axles together.. even the G80 does that technically.  It's just not the best at doing it reliably.  For the average guy the G80 works great and will get you going with one tire on sheer ice and one on dry pavement.
Open diff in a straight line with hard acceleration or rain/snow and only thing moving is that right rear tire, left rear is just sitting and waiting around haha
At least that was how my 02 acted with an open diff.
I HATED driving that truck in any icy weather with the open diff.
I can't say much about how reliable the TrueTrac is though, I only had it in for about 3 years before I sold the truck.
but in those 3 years, it was rock solid!
My new truck has the G80, so i'll roll with that, but with the AWD system i'm not too worried about it.
IMO i hate the G80 "auto locker" if you high center the frame on snow like i have plowing.... that rear diff will NOT lock. Give me a mechanical locker any day of the week. i understand why they dont though. people would accidentally leave them engaged and grenade their rear ends....
I'm a big fan of locking rear ends. I have had FWD cars with LSD that worked very well.
 The only issue I have with my current vehicle, is that the rear end doesn't like to unlock. Once its locked, I often have to move forwards and backwards while turning the steering wheel back and fourth. I wonder if I need to change the fluid.
    Anyone have any recommendations on the rear end fluid for an '03 'Burban?
Pretty sure its a difference of 100 rpm, at least that's what it is with my 17.
Whatever you do, don't give it too much throttle when your not moving on ice. I did that with my 2010. Drive wheel was on ice, and when it locked up the other wheel which found pavement. It literally sounded and felt like it blew up. Never worked right after that.
Really wish the Silverado had an electronic locker. Auto is great on ice. But in my mind I either want or need 4wheels active or two wheels active. No in between crap. I'm not worried about fuel economy unless I'm driving in ideal conditions, and on the highway.
    needafix
    needafix
  • Who's Online   5 Members, 0 Anonymous, 587 Guests (See full list)
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
