Does anyone have information on any available lowering kits or maufacturers plans to release the parts needed to lower the 2019 trucks?
Thanks.
Look up the company “Phat Phabz”
They have done a nice slammed Silverado for SEMA for the last several years
here is the 2019 Silverado they did
That a full custom built frame and all. That's a lil more than lowering shackles, springs, or an air ride setup.
That Mcgaughy kit is a bit too much but the Belltech looks about right!  Hopefully it will be released soon.
Thanks
I'm glad I have a '17.  This new body requires a C notch and 22s for a  4/6 drop and there's no fitment for 4wd. :shakehead:
  • 3 months later...
On 3/9/2019 at 9:26 PM, mafd2 said:
Belltech says 2" shackles being released next month.
Belltech told me "it will be coming out next month" in December and then again in January.
Lol I hear ya.
Hopefully Belltech will have something soon...all I'm looking for is 2" front and rear.
I just picked up my 2019 Sierra and I checked Belltechs site, and still no product for the lowering shackles. Hopefully they come out with something soon!
I have contacted Belltech and they said August / September!! Hope this is accurate!
    whenindoubtuseahammer
  • Who's Online   1 Member, 0 Anonymous, 505 Guests (See full list)
