Vibration/Buzzing in gas pedal when accelerating
jdaddy33
I have recently noticed a vibration, or buzzing on my newly purchased 2018 GMC sierra 1500. I feel it in most in the gas pedal while accelerating. I don’t notice it while cruising on the highway, mainly just during acceleration, or 1500-1900 rpm’s . I don’t feel like it was there when I first purchased the truck. I think I started to feel it around 2,500 miles (now at 3,000). It’s driving me nuts! I’ve read through the few threads listed on here and others have experienced it, but not a whole lot of solutions. Some feel it is an exhaust, resonating issue. Others used tape, wedged up under the pedal assembly (really? double sided tape on my new 60K vehicle!?!?). One person said they took theirs in and it was the 4 wheel drive not fully disengaging. I will say about a month ago I was cleaning the dash and knocked the 4 wheel drive switch over to 4H and didn’t notice it until I started it up the next day and drove to the end of the street… could that of done anything? I guess before I call the dealership, I wanted to see if I’m just being crazy, and this is normal feel for these trucks. Just can't seem to let it go, and is now I can think about while driving it.
I have a similar issue. Under acceleration around 1600-2100 RPM I hear a vibration noise but it sounds like a heat shield that is loose. It’s mainly coming from the passenger side, or at least that’s where it sounds like. I have checked everything on the dash and in the glove box with no fix. I’m curious what other may say about this.
If you have an electronically controlled transfer case, you didn’t hurt it by inadvertently switching it to 4Hi. The transfer case won’t switch unless it won’t hurt the truck under that scenario. If you ever see that the knob’s indicator light isn’t lit (as in completely off) when you have it at a certain setting, that means it’s not engaged at that setting and you need to turn the knob back to the previous setting for the light to return.
For example, if you were in 4lo and tried to switch to 2wd without switching to neutral or while traveling too fast. Even though the knob physically points to 2wd, the knob’s light would turn off. When you turn the knob back to 4lo, the light would return (on 4lo). In that scenario, the transfer case won’t change until you switched the knob back to 4lo and followed the proper procedure to go to 2wd.
When the light is flashing, the transfer case is shifting. When it’s solid, it’s engaged. When it’s off, the knob’s position doesn’t reflect the transfer case’s actual engagement.
Unfortunately, I don’t have an answer about the pedal issue you are having.
  • 1 month later...
Did you ever take it in or find a solution? I have the exact same gas pedal feedback as you, its driving me nuts. I have had a 14, a 16 and now the 18' all the same configs, CCSB. The 14 and 16 were flawless.
    • I work at a Chevrolet dealership & hear it all believe me.  Just reads like there's going to be a fist fight over filters.  Can't get enough, continue!!
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
    • Yes that's right, it's the upgrade that includes the overload spring and all that stuff.   Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings.   Exactly  you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
