2013 6l80 Issues
Not sure if correct section to post this
My 2013 silverado  6 speed auto (6l80) started downshifting hard/delayed in lower gears and makes my truck feel heavy when coming to a stop . Also makes a rattling sound sometimes  when cruising in higher gears (30-40 mph) with low throttle opening and goes away once I give it a little more throttle.  When it makes the rattling sound feels like something is not engaging and it goes back to normal as soon as I give a little more throttle. Under than that the shifting feels good.  What can it be ? torque converter?
You definitely want to get this hooked up to the proper scan tool, like a Tech-2, so you observe what's going on inside and see if the transmission has thrown any codes.  If you join AllDataDIY, you can run through the troubleshooting guide with your symptoms.
Any check engine lights?  Any pending codes or codes stored?  How long have you had the truck, and how many miles?
1 hour ago, riverbanks said:
Wondering if that's the flapper in the exhaust sticking closed?
OP has a 2013.  Flapper didn't get added until 2014 body style.
It has about 86k miles. Have had it since 2014 with 30k miles. No TCM codes just got it scanned earlier . Not sure what to do now. My friend has a  matco maximus 3.0 not sure whatever diagnostics i can do
