Jason Walkden Posted December 20, 2018 Posted December 20, 2018 I have a 2017 Elavation, what a pile of JUNK. destroyed summer and winter tires in 30k, took to dealer had to argue with them about alignment they ended up fixing the issue but never told me why is was out so bad. 10K later passenger wheel bearing goes. gm replaced 5K later had them replace rear springs because of noise been complaining about 4x4 noise dealer claims noise is normal (BS) now at 55K drivers side wheel bearing is gone. Professional Grade My A@#
Sierra Dan Posted December 20, 2018 Posted December 20, 2018 Are you at stock height or is there any lift or level? No truck out there will be flawless.
Snowcamo Posted December 20, 2018 Posted December 20, 2018 I'll helpwith your all of your issues by trading my 2014 wt. It will come with aftermarket 20s and new lower lcas. With this down grade in models your set with no worries and will still have the 4x4 capabilities as before. I'll take on your current issues with a thorough mud bath followed by a shade tree wd40 treatment. LolSent from my LG-G710 using Tapatalk
Jason Walkden Posted December 20, 2018 Author Posted December 20, 2018 3 minutes ago, Sierra Dan said: Are you at stock height or is there any lift or level? No truck out there will be flawless. bone stock
Sierra Dan Posted December 20, 2018 Posted December 20, 2018 Sorry about your troubles Jason. Seems to be a problem child or two out there in the whole grand scheme of things. Do you plan on trading it for something else or selling?
Jason Walkden Posted December 20, 2018 Author Posted December 20, 2018 as soon as I can make a trade with out flipping negative equity forward I will be. Nissan Titan here I come
Snowcamo Posted December 20, 2018 Posted December 20, 2018 as soon as I can make a trade with out flipping negative equity forward I will be. Nissan Titan here I comeI drive one for work. Omg.... I Bet it's geared different in the rear. Off the line can be dicey if you don't have a light foot.Sent from my LG-G710 using Tapatalk
Donstar Posted December 20, 2018 Posted December 20, 2018 27 minutes ago, Jason Walkden said: as soon as I can make a trade with out flipping negative equity forward I will be. Nissan Titan here I come Maybe try another GM dealership or get GM customer support involved. . Your issues should be covered under warranty. I had problems with my '09 Sierra that required a lot of warranty work. It gave me 100k of trouble free driving after the warranty expired. Your warranty is to ensure you truck operates as it was intended. Once I figured out that I needed to be respectful and persistent, the warranty process worked well. I ended up buying another Sierra in 2015 and it has been almost without flaw.
Loco-diablo Posted December 20, 2018 Posted December 20, 2018 Luck of the draw I guess. Not all of them will be perfect.. My 2017 Silverado Midnight has been flawless for the first 18 months, 28K miles... ZERO problems... ZERO recalls.. The GY Duratracs are holding up well with even wear across all of them. My last TWO trucks had rear end issues right out of the gate.. My 1999 Ranger AND my 2008 Tacoma BOTH had rear end replacements with under 500 miles on them.
