New guy from Va
HIGHCOUNTRY54
Hello. I have been lurking around for a while and have benefited from all the great information here so it’s time to join in. Have been a Chevy guy all my life and currently own two. 15 Silverado 2500HD high county duramax and a 69 camaro rs convertible. Happy new year to all.
Welcome, lived in Alexandria for 17 years back in the 70"s.   Can't say I really miss it!!
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
